20 Most Recent
Electrolux UltraLux 2000 Bagged Canister Vacuum Questions & Answers
I need a new power
You can buy the hose at an authorized Aerus Electrolux store. If near enough, they will deliver, if too far, they can ship it. The nearest dealer can be found using the below link. Just follow the instructions.
Just provide the model of the machine. They will know what hose you need.
http://www.aerushome.com/storelocator/
Need diagram to replace cord
I'm sorry, but diagrams for these machines are only available to the owners and service techs at Aerus Electrolux stores. No hard copy, and nothing on the net.
I don't recommend doing it yourself anyway, for the following reasons.
1. risk of breaking tabs.
2. unable to reassemble correctly
I strongly recommend taking it to your nearest Aerus Electrolux store.
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
My back wheel won't roll on my electrolux
Hi you need to find a local Vacuum repair place one that deals in Electrolux, and go there and take the vacuum or the make and model, and ask for a replacement part, that is the only way that you would be able to obtain spare parts, in fact while you are there, perhaps even inquire as to how much it may cost to do it? ask for a "Quote" and go from there.
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Electrolux 2100
Call your local Aerus Electrolux office. If there is a problem in the electrical system you should get that checked before you continue with the machine. As for the cord replacement- Any Aerus service dept. can do that for you. I say an Aerus office because should you let a non-Electrolux employee work on it you will void your warranty.
