Samsung Yepp YP-T7JX MP3 Player Logo
ASIM SEYAL Posted on Jan 12, 2012
My ipod freeze
My ipod freezed when i took out the chager
My 40Gig 3rd (?)generation IPOD freezes Itunes, and having reset it several times still does not work in Itunes. It will play songs as a stand alone unit but is not recognised by itunes or my computer...
With this issue if when you connect your ipod to itunes it freezes
it is one of 2 issues
1) Your ipod has an error on the disk and the computer cannot read so it freezes - in this case it is a hard ware issue with the ipod and you need to get it repaired
2) Your anti- virus is trying to scan the ipod for virus and it can so rather then letting the ipod connect to your cpu it freezes the process till you disconnect the ipod -
A great test would be if you can take this to another cpu and try it if it freezes that cpu too then it is the ipod - if it works fine then it is the anti-virus you need to stop the scan and fix process.
ITunes screen freezes on connecting the iPod. The ipod is not detected by iTunes even in disk mode. No menu of iTunes opens up when iPod is connected
if itunes is freezing when connecting the ipod then 1 of 2 things are happening
the ipod has an error on the disk and needs to be replaced or your anti- virus is going to scan your ipod for virus and can because its an ipod -
so test your ipod with another cpu that will tell you alot
if it freezes itunes on 2 different cpu then its the ipod -if it works fine then its your anti-virus - you need to disable or remove
norton is Nestorius for this
Ipod 4th gen freezes even on the restart screen.
Describe your How to reset apple ipod Model- A1285 model Security lock Number Reset Problem
IPod freezes during use
The best thing to do wuld be to first, back up all of the stuff on your ipod, and the restore it back to factory setting through itunes. After that, you can put all of your files back on the ipod and it should function normally.
My iPod Nano has had no problems in the past. But yesterday I bought a new cd and imported the songs to my ipod. The cd seemed to have some problems and we took it back to the store because it was freezing...
i can help you with the song part. if you plug in your ipod to your computer and it picks it up. go to tools folder options and click show hidden folders go to ipod control and then go to music and copy all of the songs to your computer!
Fix Ipod Nano 2nd generation (i no it's a long shot)
my firend took hers in and got anew one when u shake it does it change the siong
Ipod 80G freezing
Try uninstalling and reinstalling iTunes.
If problem persists, restore again.
If after this it is not solved call Apple.
Ipod dead after using altec lansing im600
YES.. it possibly the caused why your ipod was damaged.
Ipod nano keeps freezing
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
www.apple.com/support/ipod/five_rs/
let me know if you need more assistance.
make sure you eject the ipod first from itunes.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
