When resetting the mailbox password it says to press "yes" after entering the reset password and after #!
SOURCE: Cannot Reset Password
feature 983 ... password 12000 or 1020000 generally. Hit mail box. enter mailbox #, reset password.
SOURCE: Nortel T7316E need to reset all the password
How to Change a Mailbox Password
1. To access the voice mail system press Feature.
2. Press 9 8 3.
3. When you see Log: enter ~ SETNNA (738662) and press OK
4. Pswd: CONFIG (266344)
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
SOURCE: I locked myself out of my voicemail for Norstar M7310!
Feature 983 is system admin
1. Log into system administration
To Reset a Mailbox Password:
2. Select the softkey under “MBOX”
3. Select the softkey under “Chng”
4. Enter the mailbox number you want to reset the password for
5. The display shows “Reset Password”
6. Select the softkey under “RESET”
7. Press the release key
*The new password will be “0000′, the system will ask the user to change
SOURCE: Password Reset for Norstar M7208
ok,
First thing is the M7208 set has no soft buttons as you can tell; using the * button for YES and the # button for NO.
The line button is alittle more tricky, since you have to go into the programming of the system. What do you mean the LINE buttong may light up? Is this a telephone line? Or is this an extension line?
Do you have the programming template, it's a piece of paper that you lay over the key to tell you where the NEXT, BACK, ENTER keys are...
If you do not have the template here is a link...
If you have the line number that you want to ring on your set continue with the instructions:
-> FEATURE * * 2 6 6 3 4 4
-> password: 2 6 6 3 4 4 (this is default and might not let you in)
if that password does not work try 7 2 7 5 8 7
-> you will now see TERMINAL&SETS hit the ENTER
-> type in your extension number and ENTER
-> you will see LINE ACCESS hit enter
-> you will see LINE ASSIGNMENT hit ENTER
-> type in the line you want to ring on your phone EX:: 001
-> hit the CHANGE button till says APPR&RING
-> hit the NEXT button and RLS.
SOURCE: Need to reset my voicemail password without original password
To reset password on any tel set go to main set and press feature 983 this gets you in to programming you need a password and default password is normly
120000 for 2 digit locals and 1020000 for 3 digit locals etc.enter this password and press ok go in to
mbox type in mailbox press change , press reset password. hope this works
