Cooktops Logo
Randy Parker Posted on Jan 04, 2012
Where to get replacement knob for Wolf 36" gas cooktop
I need a replacement knob for my Wolf gas cooktop (CT36G-stainless) because the plastic insider one of my knobs has broken. I've looked everyplace I can think of online, and also checked locally with the store where I bought it - Factory Builders Store in Houston (they have been no help - won't be buying from them again) and other Wolf retailers. Called the Wolf customer service number - they require not only the Model number, but also the Serial Number, which requires pulling out the cooktop (not easy, and it's mounted over my oven) or scheduling a service call with a Wolf repairman to find the serial number and order/replace the knob. I cannot imagine how or why is it this difficult to replace a knob on this appliance. The knobs on this model are plastic on the inside, and the plastic breaks easily - if they were all metal, this wouldn't be an issue.
5 Related Answers
Anonymous
  • 2028 Answers
  • Posted on Jul 08, 2008
SOURCE: Jenn Aire Cook top
Here's a link for Jenn Aire parts dept. There's a toll free number that you can call and I'm sure they will be able to help you find replacement knobs and the glass top.
http://www.jennair.com/content.jsp?name=parts_stores
Anonymous
  • 338 Answers
  • Posted on Jan 18, 2009
SOURCE: Gas cooktop surface
Stainless is hard to clean if you dont keep up with it. Black is horrible because you see every imperfection. white turns color after some time..
I suggest stainless if you keep up with it.
Anonymous
  • 8619 Answers
  • Posted on Jul 31, 2009
SOURCE: Have Jenn-Air 36
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Anonymous
  • 582 Answers
  • Posted on Aug 26, 2009
SOURCE: Hello: One of the five knobs on the top of our GE
DARYL - GO ONLINE TO REPAIRCLINIC.COM AND YOU CAN FIND THE KNOB YOU NEED, THEY MAY SELL THEM SEPPERATLY I'M NOT SURE BUT THERE PRICES ARE THE BEST I'VE SEEN IN A WHILE
Anonymous
  • Posted on Nov 27, 2009
SOURCE: I'm looking for replacement knobs for my Jenn Air
I agree...the knobs are a POS.......redesign needs to happen....
How do i turn off child lock
I expect you have found the solution by now since this post is so old - but for any other that are searching, just push the child lock knob down and turn the knob and it should pop back up, turning the gas back on.
1helpful
Gas burner will not stay lit. works fine when pressing knob for igniter function but goes out when knob is released
You have what we call a flame safe device fitted to the burner, (thermocouple lead), have you checked to make sure your flame on the burner is touching the tip of the "probe" on t'couple, if it isn't make sure that the ports on the burner are clear. If this does not solve problem then the thermocouple needs replacing by a Gas Safe engineer.
I need 4 replacement knobs and I cannot find them!! Please help
Hi and welcome to FixYa, I am Kelly. I am assuming that your model number is MGC5430 as listed in your post. If not use this link to find them by entering your model number:
(just note that there are 2 to 5 digits missing from your model number)
http://www.appliancepartspros.com
See this page:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MGC5430
It brings up the following models:
arrow_link.gif MGC5430ADB SURFACE UNIT- GAS arrow_link.gif MGC5430ADC SURFACE UNIT- GAS arrow_link.gif MGC5430ADQ SURFACE UNIT- GAS arrow_link.gif MGC5430ADW SURFACE UNIT- GAS arrow_link.gif MGC5430BDB SURFACE UNIT- GAS arrow_link.gif MGC5430BDB20 36`` GAS COOKTOP arrow_link.gif MGC5430BDQ SURFACE UNIT- GAS arrow_link.gif MGC5430BDS SURFACE UNIT- GAS arrow_link.gif MGC5430BDS20 36`` GAS COOKTOP arrow_link.gif MGC5430BDW SURFACE UNIT- GAS arrow_link.gif MGC5430BDW21 30`` GAS COOKTOP
I used the MAYTAG MGC5430BDB20 as a reference and the BLACK knob is item 6 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5515609&diagram_id=28426062#d28426062 Detailed view is here: http://www.appliancepartspros.com/part_details.aspx?part_id=4100044 If you need more assistance please respond with a complete model number and I will use other sources to loate your knobs. Thanks for choosing FixYa, Kelly
Our cooktop knobs for our model JGC8536 Jenn-air cooktop are made of plastic and melt if a pot gets to close. Are there any metal knobs available?
What color is your cook-top? The stainless model may have actual steel knobs.. End your model number with "s" when looking for the parts..
If you have stainless and they are still plastic "stainless look" knobs then call the manufacturer as they would be the only ones to be able to determine if there is a metal knob available for your unit.
Scratches on New Wolf Gas Cooktop
The good news is you have a great product! You just need technique and the "Green" cleaner DeBruce Polish. Use DeBruce Polish and a cloth for clean ups. DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. We buy Debruce Polish at debrucepolish.com
  • Firstly clean with DeBruce Polish to clarify area.
  • you may have to "re-grain" those finely scratched areas.
  • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
  • -Re-clean with DeBruce Polish. Touch ups are now a breeze.
1helpful
How to remove the knobs and replace gas valve on DCS 36" gas cook top - looks like wobbley stem.
The knobs should just pull straight off. Don't tilt or bend them around, just pull them straight. off.
Wolf Oven
Use DeBruce Polish for the stainless steel and smooth cook tops. We get DeBruce at debrucepolish.com
2answers
Ge 36
You may need to consult near you an electrial engineer this couild be happened you need to design all parts of igniton line / many thing to change replace the switch knobs iugniter tips terminals and wirings also high voltage igniter coil. so many thing thing to buy.
Jgp963 shorting out
What do you mean you 'placed container on all five knobs'?
Apart from that it sounds like you have a faulty lead, or the contacts inside the unit have short circuited. This is the only thing that could be causing a continuous circuit and tripping the fuse.
Top Wolf Range Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Wolf Range Cooktop Expert? Answer questions, earn points and help others
