20 Most Recent Maytag MGC5430 Gas Cooktop Questions & Answers
2answers
Maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
10/16/2021 1:00:47 PM • Maytag MGC5430... • Answered on Oct 16, 2021
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
11/28/2014 7:32:14 PM • Maytag MGC5430... • Answered on Nov 28, 2014
0answers
Need new knobs for my stovetop model no. MGC5430
zip tie around cuff. works great!
8/18/2013 6:04:55 PM • Maytag MGC5430... • Answered on Aug 18, 2013
Maytag gas dryer, ignites and then shuts off after 5 seconds
Are you sure you don't have the cord all in a ball or check to make sure your getting gas there.
3/11/2013 11:07:02 PM • Maytag MGC5430... • Answered on Mar 11, 2013
2answers
I have a cookto maytag
Hi zwerling,
Moisture or water have come into contact with your ignition devices, they just need to be dried.
Please follow my directions on the Tip below on how to do this:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
11/11/2011 6:49:47 PM • Maytag MGC5430... • Answered on Nov 11, 2011
The regulator seems to be closing off completely,
I HATE TO TRY AND EXPLANE THIS FOR FEAR SOME THING MAY GO WRONG DID YOU FOLLOW THE INSTRUCTIONS TO THE LETTER. FROM NATURAL GAS TO LP YOU SHOULD OF HAD TO CHANGE THE POSISTION OF THE ORVICE IN THE REGULATER THAT IS WHY YOU ARN'T GETTING THRU THE REGULATOR CHECK YOUR DIRECTIONS AGAIN SOME TIME YOU HAVE TO THIGHTEN THE NUT ON THE REGULATOR SO IT DISTORTS THE ORFICE TO LP, AND SOME MODELS YOU HAVE TO TURN THE ORFICE OVER. BECAREFUL AND TRY AGAIN
2/6/2011 12:41:58 AM • Maytag MGC5430... • Answered on Feb 06, 2011
I need 4 replacement knobs
Hi and welcome to FixYa, I am Kelly. I am assuming that your model number is MGC5430 as listed in your post. If not use this link to find them by entering your model number:
(just note that there are 2 to 5 digits missing from your model number)
http://www.appliancepartspros.com
See this page:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MGC5430
It brings up the following models:
arrow_link.gif MGC5430ADB SURFACE UNIT- GAS arrow_link.gif MGC5430ADC SURFACE UNIT- GAS arrow_link.gif MGC5430ADQ SURFACE UNIT- GAS arrow_link.gif MGC5430ADW SURFACE UNIT- GAS arrow_link.gif MGC5430BDB SURFACE UNIT- GAS arrow_link.gif MGC5430BDB20 36`` GAS COOKTOP arrow_link.gif MGC5430BDQ SURFACE UNIT- GAS arrow_link.gif MGC5430BDS SURFACE UNIT- GAS arrow_link.gif MGC5430BDS20 36`` GAS COOKTOP arrow_link.gif MGC5430BDW SURFACE UNIT- GAS arrow_link.gif MGC5430BDW21 30`` GAS COOKTOP
I used the MAYTAG MGC5430BDB20 as a reference and the BLACK knob is item 6 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5515609&diagram_id=28426062#d28426062 Detailed view is here: http://www.appliancepartspros.com/part_details.aspx?part_id=4100044 If you need more assistance please respond with a complete model number and I will use other sources to loate your knobs. Thanks for choosing FixYa, Kelly
1/5/2011 10:53:46 PM • Maytag MGC5430... • Answered on Jan 05, 2011
I have the same problem
One or more of the ignitor switches has shorted out.
You have 4,one each on the valve stem behind the knobs for each burner.
1/5/2011 9:25:04 PM • Maytag MGC5430... • Answered on Jan 05, 2011
Maytag MGC5430 cook top range IGNITION KEEPS
This sounds like a burner switch.There is one under every knob there are two wires going into them. i think the part number is 7403P367-60.
12/7/2010 5:30:57 PM • Maytag MGC5430... • Answered on Dec 07, 2010
Have a Creda gas cooktop. This evening all four igniters began to spark without turning the burner control. All were in off position. Sparks of course stop when the plug is pulled. The cooktop was not
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/5/2010 2:58:29 AM • Maytag MGC5430... • Answered on Sep 05, 2010
MODEL MGC543OBDS GAS STOVE THE ELECTRONIC STARTERS
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
8/19/2010 12:18:03 AM • Maytag MGC5430... • Answered on Aug 19, 2010
I do not get spark,
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
8/18/2010 9:46:23 PM • Maytag MGC5430... • Answered on Aug 18, 2010
Maytag gas cook top. One burner will not spark.
Took entire cook top apart, dried each of the components then reassembled. I donot recomment this unless you are very handy. Not an easy job but doable. Also
try to dry it out with a hair dryer on low.
11/30/2009 2:59:16 AM • Maytag MGC5430... • Answered on Nov 30, 2009
I have a 5 burner gas cooktop that is chrome
Your Maytag authorized dealer can help. Otherwise take the top to a chrome plating service.
10/29/2009 9:27:08 PM • Maytag MGC5430... • Answered on Oct 29, 2009
Maytag MGC5430 Gas Cooktop Logo
26 questions posted
Top Maytag Cooktops Experts
Paul Carew
Stan Ford
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Maytag Cooktops
  • Maytag Cooktops
Most Popular Question
maytag gas cook top one burner will not
  • Cooktops
