20 Most Recent
GE 36 in. Profile JGP963 Stainless Steel Gas Cooktop Questions & Answers
I have a GE JGP963 gas cooktop. When you turn the
Hello, Is this a new unit? Is it still under warranty? Has it been recently worked on or converted to another type gas? I'd call the manufacturer (or the company that installed it) and have them send out a qualified technician to fix it. Are the burner flames a nice even blue color? Can you adjust the flames from high to simmer without them going out. If it was converted to another gas type, it's possible the wrong size orifices were put in or possibly that it needs to be converted because it is a natural gas unit that should be changed to propane, or vice-versa. Also be sure the appliance regulator was switched over to the correct type of gas. These are just a few ideas that come to mind. Let me know if any of these apply. Douglas
9/12/2010 4:38:57 PM •
GE 36 in....
Answered
on Sep 12, 2010
I use one of the large burners most of the time
I am not sure of this Model but most of the Gas Rail Cocks ( Taps) when you remove the knob you will find either a small hole drilled into the spindle This would be the Low Burner (simmer Rate) Adjustment there would be a small screwdriver requiredto do this , if its not there ,then there is usually a small screw on the side of the tap under the Knob Hope this will help you
7/23/2009 12:34:54 PM •
GE 36 in....
Answered
on Jul 23, 2009
Gas not igniting
aknot, make sure each burner cap has a good ground to the burner. You can use some light sandpaper to scrub them. Where the burner fits around the ignitor is a small orfice. Use a paper clip or small sharp object to clean out the orfice. Try this first. Catriver..post back.
3/31/2009 5:33:25 PM •
GE 36 in....
Answered
on Mar 31, 2009
Ge 36
You may need to consult near you an electrial engineer this couild be happened you need to design all parts of igniton line / many thing to change replace the switch knobs iugniter tips terminals and wirings also high voltage igniter coil. so many thing thing to buy.
11/17/2008 6:59:55 PM •
GE 36 in....
Answered
on Nov 17, 2008
Jgp963 shorting out
What do you mean you 'placed container on all five knobs'?
Apart from that it sounds like you have a faulty lead, or the contacts inside the unit have short circuited. This is the only thing that could be causing a continuous circuit and tripping the fuse.
1/2/2008 3:54:00 AM •
GE 36 in....
Answered
on Jan 02, 2008
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
2/17/2021 6:49:19 PM •
GE Cooktops
Answered
on Feb 17, 2021
