I got a Nikon D50 a couple weeks ago W/out a charger. It was reading a Low Battery, and saying a "CHA" error message, which I fixed myself after reading up about it (the SD Card). I got a charger now, a Nikon Quick Charger, and I charged the battery for about an hour. It's still saying low battery and won't let me access the Menu screen at all. I got the Cam from my sister and she says it might be the battery reader inside, she got a new Cam, but had gotten a new battery for the D50 first, to try and fix this problem before she had given it to me. No luck. Any help or suggestions with this would be greatly appreciated. Thanks much.
The SD card has nothing to do with your problem. Make sure that the battery is good; i.e., it is both taking and holding a charge. If you have a voltmeter, look at the back of the battery just under the three electrical contacts. You will see that they are labeled "-", "S" and "+". After charging the battery, measure between the "-" and the "+". It should measure 8 volts DC. Then measure between the "S" and "+" and it should also measure about 8 volts.
Next, you need to see if a short circuit in the camera is loading down or draining the battery. Put the battery in the camera. Keep the camera turned off and leave it overnight or for a day and remeasure the voltage. If it has dropped more than a 100 mv (0.1 volts) the problem may be with the camera. If that is the case, you will need to send it in for repair.
SOURCE: Nikon D40 Error Message
Get the kit changed. That should not happen right out of the box, but make double sure the next time around, you charge the battery completely before using it the first time. Not doing this can cause problems.
SOURCE: my Nikon D50 camera says
It thinks that the SD card is full - try re-formatting if you have no photos there. The SD functions the same as a PC hard drive, and if the directory 'tracks' are corrupt, anything could happen. Else try a new SD card.
SOURCE: I have a Nikon D50 with an error message "CHA"
This error indicates the following:
This card cannot be used (CHR) blinks.
Problem(s)
Error accessing memory card
Unable to create a new folder (on card)
Card has not been formatted for use on D70
Try another card
Format the card using your D70 (all images will be erased)
Check the card for visible damage or poor contacts.
You may have inserted a memory card that was been used in a different camera or the formatting process did not complete successfully.
I hope this helps.
SOURCE: HI I HAVE a CHA mess in my nikon D50
CHA Error - not as bad as everyone thinks. Here is the solution, the second one has pics of how to fix the problem.
http://www.vandyll.net/?p=499
Then
http://www.stephanmantler.com/blog/d70s-camera-repair/
SOURCE: What does
You haven't provided enough details to be sure of the problem, but I suspect you have either bought a new memory card that is either the wrong type or too large for that camera. If it is still the original memory card that you first used with your camera, try reformating the card.
The 'CHA' message I already fixed. The underlying problem now, is my camera is reading/saying 'LOW BATTERY' after I put in a fully charged battery. Could it be my battery is dead? (but my camera still turns on, just not fully, like I can't access the menu screen) Or could it be my charger? (when I put the battery on the charger it flashed until it stayed lit, hinting it was charged) Or could it be the inside of my Cam where the battery goes, like not reading that the battery is charged? The camera/battery isn't fully dead, it still turns on but just enough to let me know that the battery (which I've charged) is dead. any help would be greatly appreciated. thanks.
Why does my Camera say 'low battery' when the battery is being fully charged before inserted in camera? Camera problem? Fuse problem? I bought a new battery and same problem!??!!?
After reading the D50 manual, it says if a low battery icon is blinking the battery may be exhausted and to replace it. I'm going to try buying a new battery, again, and see if this is the solution. I'll post back if it works or not for future solution seekers.
