Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
SOURCE: Settings saved on the computer for the netword do not match the requriements
try HERE for info too
SOURCE: connecting to dlink-524 on vista
your key code is the the code that you set fpr the key code di you write it down like it tells you to
SOURCE: trouble connecting on my netgear router model wgr614v7
Posted a solution on your other thread:-
http://www.fixya.com/support/t1594223-netgear_wgr614v7_network_security_key
SOURCE: 'The settings saved on this computer for the
Well, follow the steps below for a better way to configure your connection:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Now perform the steps below on the wireles vista computer:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
I hope the steps above will help resolve the issue. If you need any further help please email us back so that we can continue to work on a solution.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
SOURCE: router not connected
First You will need to remove the network from the preferred network list.
Then check the wireless settings on the router. Is there any computer connected to the router ?If ot then you will need to connect the computer to the router . open the set up page f the router. check the security settings on the router,
The try to conect , it will connect.
Click here for more information about how to conect to the wireless network
