Lenovo replaced my motherboard and my bluetooth module yet it still wasn't working then they had me reformat my computer using the hidden partion now this message pops up Bluetooth Stack COM Server has stopped working Problem details:Problem signature: Problem Event Name: APPCRASH Application Name: BtStackServer.exe Application Version: 6.3.0.4300 Application Timestamp: 4bacfd78 Fault Module Name: StackHash_2c1a Fault Module Version: 6.1.7600.16559 Fault Module Timestamp: 4ba9b802 Exception Code: c0000374 Exception Offset: 00000000000c6df2 OS Version: 6.1.7600.2.0.0.768.3 Locale ID: 1033 Additional Information 1: 2c1a Additional Information 2: 2c1a0ae0110afdbf1f3317d9ab6f8ab1 Additional Information 3: 461b Additional Information 4: 461b034c43e502bf4ba5888dc409f748 It then gives me the option to send the error or not either way the message bluetooth stack com server has stopped working pops back up.
SOURCE: Lenovo Y5230 Bluetooth
The easiest way for you to find the correct driver is to find the name of your Bluetooth device through your ystem information page. Click on start>programs>accessories>system tools>system info.
Then go to the original manufacturers website and download drivers. This will activate your Bluetooth.
Don't forget to rate this solution.
SOURCE: Problem Event Name: APPCRASH Application Name: iexplore.exe
the nice thing about IE7 is that it has a nice easy way to fix alot of problems.
click on tools, internet properties, advanced and then click the last button on the page, the one about resetting to defaults..any bad or bogus addons become disabled and any bunged up security settings go to their defaults.
after this, you'll have to re-enter your homepage and install addons like flash player and java, but that generally solves any issues you might be happening. what is the website? it could not be a problem on your end but some bad code in their site.
SOURCE: A problem regarding bluetooth
You need to install the bluetooth software, if you have a disk, install from there. Otherwise look on the manufacturers website for the drivers and other software you may want. the bluetooth device itself is just the hardware, you need both the software and the hardware, good luck,
PS, also mention what operating system you have, because XP doesn't support it even though it will work on XP, that's a MSFT thing,they would rather say they don't support something than have it work properlly with their software
SOURCE: Lenova computer running Vista crashes
Weird category. Seems OS- or program-specific enough.
The exception codes are supposed to give you insight into what's going on, (Intel exceptions C000 00029 and E043 4F4D in the context of Vista or your CPU in particular, say) but perhaps you should try the Vista equivalent of WinXP's RunAs options, where you can run them as older applications and dodge some incompatibilities.
Similarly, you might want to create a VM (or runtime jail; many, many options to be had there...) and try it in that context, so that if the program's spoiling things at least your system won't need to worry or crash. The easiest thing of course is to find updates of those programs that promise to play well with Vista.
