20 Most Recent Acer Aspire 5580 Notebook Questions & Answers
if you changed the screens to a working one, then you should have a clear image on the main screen, or its damaged, or one of the monitor ribbons is not seated properly. have you updated your graphics driver?
Acer Aspire 5580... | Answered on Sep 19, 2017
time to get a new one.
Acer Aspire 5580... | Answered on Apr 05, 2015
Here's the solution. I had to replace a failed hard drive in a Vista laptop. The original drive was a 200GB and I replaced it with a 500GB. I used my original Toshiba restoration CDs. I've spent HOURS troubleshooting this problem and I never would have guessed the solution -- it's the Intel Rapid Storage Technology Driver. It has to be updated because of the larger drive.
Here's a link to an HP support site for the updated driver. You can also find the update on Intel's site.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02219204&cc=nl&lc=en&dlc=en&product
Acer Aspire 5580... | Answered on Nov 07, 2014
here are 2 password type first 1 is bios password if tell me about your bios password it prompt when u powerup follow procedure below
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
And if u tell about windows password
Then when you power up the computer press F8 key then enter in safe mode then wait until it prompt for user password
then enter in administrator then if u able to enter then reset your password.
But if u set and forgot default administrator password then u should need winxp recovery disk.
Acer Aspire 5580... | Answered on Apr 26, 2014
Please explain, which certificate?
Acer Aspire 5580... | Answered on Feb 25, 2014
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Acer Aspire 5580... | Answered on Jan 17, 2013
Are you asking for the wiring diagram inside the main Battery?
If so, due to very possible injury, or death to you, there will be No solution.
Now, if you are talking about what is the polarity for the plug of the AC adapter, (Charger), that plugs into the DC Power Jack on the laptop, (DC _IN), then I'm on board.
The Center Hole in the plug end is the Positive ( + ) connection.
This is where the Positive (Red) probe lead of the multimeter goes.
The cylindrical outside metal shell is the Negative connection.
The Negative (Black) probe lead of the multimeter touches here.
Voltage is 19 Volts DC.
Wiring diagram for the inside of the AC adapter itself?
No gottom.
Regards,
joecoolvette
Acer Aspire 5580... | Answered on Oct 23, 2012
Go to this url,pick the type of webcam you have. .Put this URL in the search bar of your browser.PICK THE TYPE OF WEBCAM AND THERE IS WHERE YOUR DRIVERS ARE.
Acer Aspire 5580... | Answered on Sep 21, 2012
Hi dcalchin...
1. Keep pressing "F8" as the laptop computer starts.
2. When the window "Advanced Boot Options" opens, choose "Safe Mode" with arrow key and confim by pressing the Enter key, then PC enters the Safe Mode.
3. Once you are in the Safe mode Click "Administrator" on the Windows login screen.
Take note that you have set the Administrator password before, you need to input the changed password instead of leaving "Password" field blank.
4. Then click Start > Control Panel > User Accounts > Select the account that is locked and change the password.
5. Restart laptop and login into the account you just created using your new password.
Please take time to rate me
Acer Aspire 5580... | Answered on Aug 18, 2012
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
Acer Aspire 5580... | Answered on Jun 11, 2012
Some reason of hanging the laptop during opening a program is the low speed of the memory modules. But the main reason of this is the virus containing the files or programs. The best way to clear this is to reformat your laptop. You need to have an Windows CD and the installation CD of your laptop motherboard.
Regards
PCmania
Acer Aspire 5580... | Answered on Aug 04, 2011
Turn off your laptop. Power it up again. Press "F8" as the computer boots up. A boot menu will appear. Select "Safe Mode" from the list of options. Click "Yes" on the next menu to start your machine in Safe Mode. Right-click "Start" once the laptop boots up. Click "Properties. Select the "Device Manager" option under the "Hardware" tab in the window that appears. Find the "Display Adapter" icon. Right-click on it and select "Uninstall." Select the display driver from its location on your laptop when prompted. The display driver will be reinstalled. Restart the laptop when prompted. This should fix the problem.
Acer Aspire 5580... | Answered on Jul 17, 2011
There are no Windows 7 drivers for this laptop according to the Acer website. That being said, there's also the chance that it could be 3 different camera's, so choosing the correct driver might be difficult without the specifications for your exact notebook. Have you contacted Acer support at all?
Acer Aspire 5580... | Answered on Jun 25, 2011
There is an error in the OS, You need to do the recovery again,
Please tell us the results.
Good Luck
Acer Aspire 5580... | Answered on May 15, 2011
From looking at the Acer support site it looks as if they haven't sorted out the driver files for Window 7 yet for the Bison, Logitech and Suyin webcams. I've had mixed success in the past by downloading and installing the older drivers for Vista but it's pretty hit and miss. Hopefully the afore mentioned manufacturer's are working on providing updated drivers for Windows 7 very soon.
Acer Aspire 5580... | Answered on Apr 11, 2011
If you want to copy pictures back to an SD card then you need to put the card in a device such as your camera or phone it came out of and hook that device up via USB to your computer which will show up in My Computer as a drive letter. There will be a specific folder where pictures on the device are typically stored. Copy them there. May be called "DCIM"
Or if you have access to a media card reader that connects externally to your computer via usb
Example:
http://www.walmart.com/ip/Kingston-FCR-HS219-1-19-in-1-USB-2.0-Media-Reader/13075191?sourceid=1500000000000003142050&ci_src=14110944&ci_sku=13075191
Acer Aspire 5580... | Answered on Feb 07, 2011
Acer Aspire 5580 Notebook Logo
129 questions posted
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
previous owners password wont allow me
  • Computers & Internet
