20 Most Recent
Lenovo IdeaCentre A600 PC Desktop Questions & Answers
Need instructions on how to replace a motherboard
Download the "Hardware Maintenance Manual" from Lenovo's support page
here. Page 77 onwards describes in detail how to remove the motherboard.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
10/14/2011 4:11:22 AM •
Lenovo...
Answered
on Oct 14, 2011
Black screen
this can be caused by your video card or your monitor connection something that you can try is to check your connection or make sure that your video card is inserted tightly in the Pci-e slot inside of your computer case also you might want to check you computer monitor contrast...
5/23/2011 3:43:38 AM •
Lenovo...
Answered
on May 23, 2011
Where is the number lock
Most likely the numlock function is located on the upper left part of your keyboard and you have to activate it by pressing FN+NUMLOCK.
4/17/2011 6:02:39 AM •
Lenovo...
Answered
on Apr 17, 2011
My computer quite reading dvds and cds
There may be a hardware issue with your drive. However, it can also get dirty after use and just sitting there. You can buy a drive cleaner at almost any electronics retailer, and they are fairly inexpensive. If this doesn't work, you are probably in the market for a new drive.
8/2/2010 3:34:53 AM •
Lenovo...
Answered
on Aug 02, 2010
IdeaCentre B300 power failure
first check if there is power failure in your locality
check if switch is on
check if UPS is working
check SMPS
if sms ok then check motherboard
could be static current in ram
2/29/2016 3:54:30 PM •
Lenovo...
Answered
on Feb 29, 2016
Touch screen not working
Verify the driver is installed for the touch screen. Go into the device manager to verify the driver.
6/16/2015 2:07:21 AM •
Lenovo...
Answered
on Jun 16, 2015
When turn pc monitor no signal
Verify all the cables are seated. You may also have a problem with your graphics hardware or drivers. If you get the BIOS screen typically signified by the manufacturer logo, press F8 to enter safe mode. If that works then it is most likely a driver issue.
6/16/2015 2:05:41 AM •
Lenovo...
Answered
on Jun 16, 2015
Web pages and programs are to large
Two possibilities: your pc's resolution is not high enough (which means you need to go to the desktop, right click anywhere in the blank area, select screen resolution, and change it to something higher) or, your browser is "zoomed". Hit ALT (the alt key) + V (for view) go to Zoom and lower the zoom factor.
I suspect the second is the problem as it's easy to zoom (ctrl+ and ctrl- will do it too).
7/18/2014 5:53:31 PM •
Lenovo...
Answered
on Jul 18, 2014
Puk code
WHERE DO I GET MY PUK CODE?
The PUK code is unique to your SIM card, so you can only get this from your mobile network.Sometimes they will give you this when you first get the SIM card, but not all networks do this. If you cannot find it, give your mobile network a call and they will be able to give you the PUK code after you have answered some security questions
3/23/2014 8:26:17 AM •
Lenovo...
Answered
on Mar 23, 2014
