20 Most Recent
Lenovo IdeaCentre K210 - 53133BU PC Desktop Questions & Answers
I bought new lenova ideacentre
If the noise you are getting is a pulsing at the same frequency all the time you will need to find a different monitor. As the power supply is causing interference. but if you are getting the problem while recording with a microphone, then you need to earth your mic properly.
7/21/2013 8:55:15 PM •
Lenovo...
Answered
on Jul 21, 2013
Support graphics card or not
Yes, it has 1 PCIe 16x slot. This can be used for a graphics card. Just make sure the video card you get is for a PCIe slot.
9/18/2011 4:27:48 AM •
Lenovo...
Answered
on Sep 18, 2011
Goes into hibernation won't come
Try setting your screen saver to none. That might sole the hibernation problem. Sometimes a computer will go into hibernation if the screensaver has been on for a while.
3/15/2011 2:51:27 PM •
Lenovo...
Answered
on Mar 15, 2011
My excel sheet is opeaning very slow about 30 40
there could be several reasons for that:
1. do you have links pointing to another excel/website/folder/db query? if so- it is probably trying to import data from it. the most common is to try and import data from another excel sheet- you need to have that excel open before you open this on
2. what is the size of your excel file? if it's big- try to see if you can break it to several excel sheets.
3. what type of hardware do you have? do you have enough memory?
can you provide more details?
8/9/2009 6:16:57 AM •
Lenovo...
Answered
on Aug 09, 2009
When i install the sound it says that driver not
dear,
did u enable the sound from the CMOS setup...if the previous one was working then you dont have to do this.. if the case is new then check it by the way...
moreover, properly insert the card in the slot please...
goodluck.......
8/3/2009 12:45:03 PM •
Lenovo...
Answered
on Aug 03, 2009
I want to download pagemaker 5.5
5.5 is a very old version of pagemaker, as pagemaker is not free or shareware you will not be able to download this without purchasing it first, as it is so old most shops will not stock it, i recommend you contact adobe and ask them for advice on getting it but expect them to charge you for the latest version.
7/2/2009 10:09:09 AM •
Lenovo...
Answered
on Jul 02, 2009
I do not get drivers for lan cards in windows xp
Please search the driver in www.driverguide.com, its free here you will surely get the drivers in this site, before downloading the drivers you need to register for free then you can download the drivers from this site.
3/30/2009 10:04:56 AM •
Lenovo...
Answered
on Mar 30, 2009
IdeaCentre B300 power failure
first check if there is power failure in your locality
check if switch is on
check if UPS is working
check SMPS
if sms ok then check motherboard
could be static current in ram
2/29/2016 3:54:30 PM •
Lenovo...
Answered
on Feb 29, 2016
Touch screen not working
Verify the driver is installed for the touch screen. Go into the device manager to verify the driver.
6/16/2015 2:07:21 AM •
Lenovo...
Answered
on Jun 16, 2015
When turn pc monitor no signal
Verify all the cables are seated. You may also have a problem with your graphics hardware or drivers. If you get the BIOS screen typically signified by the manufacturer logo, press F8 to enter safe mode. If that works then it is most likely a driver issue.
6/16/2015 2:05:41 AM •
Lenovo...
Answered
on Jun 16, 2015
