Toshiba DKT-2010 Corded Phone Logo
Posted on Oct 02, 2008
How do you mute a conference call?
I have a Toshiba DTK 2010SD phone. Is there a way to mute while you are on a conference call?
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Oct 11, 2008
Anonymous
Contributor
Level 1:
Answers
31
Questions
Helped
20602
Points
46
To mute while you are on a conference call, the has to be on speaker then push the mic buttonto turn it off.
3helpful
I need to mute/unmute my phone for a conference call. Not sure how to do this.
Some cell phones don't mute, but a *6 will mute your phone to the conference call center, and #6 will unmute if you wish to say something. This will not mute your phone, so when you hang up...you're always good to go to make calls. It only mutes a phone (any phone) to the server conducting the conference.
Nokia 1100 Mute Reg
WHEN you are in conference ..
go to options(that is press left soft key)..dont worry the call will be continued..
then,it displays a list of options,press down until you see mute,click mute and the calls will be muted...
How do i mute a conference call in this phone. toshiba DKT 2020
The generic instuction for mute on almost all phones is *6 (star followed by 6). To un-mute just press *6 again.
There may be a specific command for your phone, but I'd be surprised if this does not work.
1helpful
I have DKT-2010SD toshiba business phone. how can i do a call forwarding for after hours?
There is a couple of way to do this. If you are trying to call forward the lines to a outside extension you will have to press Intercom #6011 9 (your phone number you want it to go to) then redial. Your second option is to get call forwarding through your telephone provider. Usually this is a low cost addition and is the way I would forward calls externally. Hope this helps.
No mute - conference calls
sounds as if you will need your vendor to program your phone and others that need be to have Handsfree/mute capabilities.. i assume since you can not mute then you can not place your phone on Handsfree either.
2helpful
Put Phone on Mute while on conference call
The button for handsfree is the same button for Mute.
So when you are on the handsfree call, press the handsfree button again and the call is muted on your side.
To talk again, press the handsfree button to un-mute the call, then press it again to mute your call.
To hang up press the orange RLS button.
Polycom sound station 2 conference set conference problem
sounds strange, it lookslike a main board problem, considering that u have been using similar unit before.there is not much that u can do from the menu options.u will have to refer ur vendor for rpairs
4helpful
2answers
How can I mute a cell phone call
While the call is active, push the left button for options and scroll to mute.
2010SD not connecting - display says Registering IPT
sounds like an ipt phone, did you program the phone? 3,6,9, hold all pressed at the same time will get you in program mode. hit 2 then make sure you have all you settings in there correctly
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
