20 Most Recent Toshiba DKT-2020-SD telephone Questions & Answers
Is the Plantronics CS510-XD Headset compatible with Toshiba DKT 2020-SD? And what model EHS is compatible with the DKT 2020-SD
You'll need an HHEU Headset Interface which installs inside the set via a ribbon cable.
3/29/2020 10:44:29 AM • Toshiba... • Answered on Mar 29, 2020
How do we re-set a voicemail on Toshiba DKT2020-SD?
Here is a link that pretty much explains it. However, it says to dial 400 to get to your voicemail system. This can vary in programming. If you have an auto attendant that answers your inbound calls, just dial 999 to get to the Administrator mailbox, and then follow the rest of the directions. http://www.telelinkcom.com/quickstart_pdf/ToshibaVoiceMailSystems/StratagyVoicemailAdminMailbox.pdf
10/21/2016 3:43:10 PM • Toshiba... • Answered on Oct 21, 2016
How to set up speed dial
I don't have that exact model, but on a similar one, u just hold down the button u want to use for the sped dial and it leads u thru the setup. Good luck
3/5/2015 6:30:40 PM • Toshiba... • Answered on Mar 05, 2015
What do i need to be able to use this phone with a headset? I have a plantronics headset but not sure if an adapter or something else is needed to enable multi line use
for headsets no adapter is required all you have to do is plug into the proper headset socket
5/10/2014 2:38:04 AM • Toshiba... • Answered on May 10, 2014
Set up auto attendant toshiba
This is a system wide setting please go to http://www.telecom.toshiba.com/ and obtain a users guide for VM specifically the administrators guide. If this does not work. Stay on this same site and find a dealer to log into the system to change the settings for you
12/31/2013 4:50:28 AM • Toshiba... • Answered on Dec 31, 2013
How do I make a voice mail message?
Call a telephone and it should forward to VM. or call into your mailbox and select to leave a message. Here is the link to our users guides.
12/31/2013 4:33:44 AM • Toshiba... • Answered on Dec 31, 2013
0answers
Mailbox passcode is uknown. used admisitrative
This depends on the voicemail system. Here are some common default passwords for voicemail.
1234
0000
1111
9999
4321
7777
Hope this helps.
1/21/2011 4:00:34 PM • Toshiba... • Answered on Jan 21, 2011
How do I forward my
This does depend on which Toshiba phone system your phone is connected to
Here are a couple possible methods
Press button
Dial 601(all calls) or 602(busy) or 603(no answer) or 604(busy/noanswer)
Dial voicemail access code(extension number of voicemail)
Press button to end
Press button
Dial #601(all calls) or #602(busy) or #603(no answer) or #604(busy/noanswer)
Press button to end
12/8/2010 7:34:29 PM • Toshiba... • Answered on Dec 08, 2010
How do i change the time on this phone?
Depending on the type of Toshiba phone system, the programming steps may vary slightly but this should get you on the right track.
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial
11/8/2010 7:41:37 PM • Toshiba... • Answered on Nov 08, 2010
The time on our voice mail retreival is wrong.
really depends on which voicemail you have. I will assume you have the toshiba voicemail. call voicemail, when it answers press * should ask for your user ID enter 999 and use 999997 as sec code or 999. press 8 then 6 and enter time
4/12/2010 6:52:06 PM • Toshiba... • Answered on Apr 12, 2010
I have DKT-2010SD toshiba business phone. how can
There is a couple of way to do this. If you are trying to call forward the lines to a outside extension you will have to press Intercom #6011 9 (your phone number you want it to go to) then redial. Your second option is to get call forwarding through your telephone provider. Usually this is a low cost addition and is the way I would forward calls externally. Hope this helps.
2/26/2010 3:18:10 PM • Toshiba... • Answered on Feb 26, 2010
Busy signal
Voice mail is probably got a blown hard drive and we fix that. or it could just use a reset. Turn off and back on or check out your manuals and guides here
http://guides.idacomusa.com/
2/11/2010 10:38:54 PM • Toshiba... • Answered on Feb 11, 2010
Toshiba DKT-2020-SD telephone Logo
61 questions posted
Top Toshiba Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Lands Phones
Most Popular Question
change time phone
  • Lands Phones
