Hello David - Typically most of the recent manufacture freezers have fan motors, however some are enclose to where you are unable to reach or see it. Are you having a specific problem with your freezer?
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Yes, it is a temperature control. You will want to turn the dial back to about the center position and then go higher or lower from there. All the way to the right will probably make the freezer try to be colder than you need and ice cream may be impossible to dip for instance. Also if you are running colder than you need to be the freezer will use much more energy. If you have a thermometer that you can stick in there go for around 0 degrees F
just about all friges work off the frezer .the evap fan moves the air fromthe frezer to the frig.so you would here fan noise.i dont know your brand but on most frezers if you turn the frezer temp to the highest setting thats acomplished by keeping the air from going to the frige.hence warmer frig temps .also make sure fan on out side back is working and condenser is clean.again turn air damper control from frezer to frige to lowest setting .somthimes this could be in frig section.God bless ,tom
Keep it unplugged and look for burned wires, or rubber wires hardened from extreme heat. This will be a good start in finding what is going wrong. One more thing to check is if the compressor is heating up after running for a while. Let it run for 20 min or so, shut off the power and feel the compressor. Is it hot?
