20 Most Recent Whirlpool 10 cu. ft. Chest Freezer EH101FXR Questions & Answers
Compressor
Locate a factory authorized technician and have them service it under the warranty, if it has one. The manufacturer should have a complete list of companies that do independent techs. I used to be a tech. for 35 different companies, so they are out there. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/31/2017 10:03:29 AM • Whirlpool 10 cu.... • Answered on Dec 31, 2017
I need the owners manual for the estate chest freezer model no. tcf1510ew00, or if someone could just tell me the temp settings for each number? it shows on the side that 4 is i guess the freezing poi
The numbers are generic and don't mean a thing. They are there to make you feel like you have control. Anything under 1 should be very much frozen. If it is not then you have T-stat problem and should address that. Chest freezers run at -25f on average if the freezer has enough product in it. The more food in the freezer the better and more efficiently it will run.
4/13/2014 12:02:42 AM • Whirlpool 10 cu.... • Answered on Apr 13, 2014
Whirlpool freezer display flashing 1
Hi Rachel For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
2/23/2014 12:00:24 PM • Whirlpool 10 cu.... • Answered on Feb 23, 2014
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
8/19/2009 4:44:39 AM • Whirlpool 10 cu.... • Answered on Aug 19, 2009
I have a whirlpool freezer, the red light on the
The light is there to indicate there is power. If it is running constantly and still not cooling properly there is a problem in the sealed system (or the door is not sealed completely, but there would be a lot of frost were this the case. Here is a link to where you can find the manual with a complete model number.
HDR-SR12E Eric
7/2/2009 12:12:00 PM • Whirlpool 10 cu.... • Answered on Jul 02, 2009
EH101FXR
The cover being gone will not hurt anything. It may be missing but its ok. Some dont even come with the unit anymore. its all ok.
11/20/2008 8:38:12 PM • Whirlpool 10 cu.... • Answered on Nov 20, 2008
Whirlpool upright freezer is working fine but an alarm is sounding intermittently. It sounds different than the high temperature alarm. Can't find codes. What does it mean?
If your Whirlpool upright freezer is working fine but an intermittent alarm is sounding that is different from the high temperature alarm, it could indicate an issue with the door or the door switch. The alarm is designed to alert you if the door has been left open for an extended period or if the door switch is malfunctioning. Check the door seal to ensure it is tight and the door is closing properly. You can also try cleaning the door switch to see if that resolves the issue. If the problem persists, it may be necessary to contact a professional for further assistance.
2/14/2023 6:46:27 AM • Whirlpool... • Answered on Feb 14, 2023
Model UW8FDXB1EX Whirlpool Upright freezer
3/12/2022 12:53:50 PM • Whirlpool... • Answered on Mar 12, 2022
The question i asked has been answered, but is there actual diagrams that i could view to see how it's done?
THIS question is your only question here on Fixya dot com! https://www.fixya.com/users/gregg-j-ajamian You just need a good search query to find stuff like this. Cut out all the extraneous words and use the bare bones. Videos in the link https://www.google.com/search?q=whirlpool+upright+freezer+EV250NXTQ03+remove+the+drain+grommet ..
10/2/2021 5:34:32 PM • Whirlpool... • Answered on Oct 02, 2021
2answers
Hello awesome Fixya Experts! How do I disable the tones/alerts for my Whirlpool freezer (model WZF79R18DM00)?
There shouldn't be any 'jingly tone' at the end of every compressor cycle. You could be hearing something else making a sound after the compressor stops.
3/8/2021 2:35:38 AM • Whirlpool... • Answered on Mar 08, 2021
Model # WZF79R20DW00. Which snowflake is supposed to make it colder?
The larger one
11/30/2020 11:12:06 PM • Whirlpool... • Answered on Nov 30, 2020
My whirlpool upright freezer is beeping every minute
The door switch or door module is defective. or the door is not fully closed
5/10/2019 9:51:02 PM • Whirlpool... • Answered on May 10, 2019
Green light flashing onwhirlpool freezer
http://www.fixya.com/tags/freezer_green_light_flashing/browse/whirlpool
3/13/2019 10:40:02 PM • Whirlpool... • Answered on Mar 13, 2019
2answers
Model EVL201NXRQ05 serial eww4020663 WHIRLPOOL UPRIGHT FREEZER - Freezer which is having ice freeze on the bottom of the freezer. What can I do?
The defrost water from the melted frost (ice) collects in the bottom of the freezer. If there is no plugged up drain, then you must remove the water manually with a sponge and bucket after a defrost cycle.
1/24/2019 3:41:51 AM • Whirlpool... • Answered on Jan 24, 2019
Model EVL201NXRQ05 Serial EWW4020663 Freezer which is having ice freeze on the bottom of the freezer. What can I do? no plug.
If it’s in floor if freezer, you have a clogged defrost drain. If it’s on inside back freezer wall, it’s a defrost problem
1/23/2019 11:07:42 PM • Whirlpool... • Answered on Jan 23, 2019
My water connection trips power after the water is turned on for a while
The solenoids that operate the ice maker and the water dispenser in the door may be getting water internally. I would put a pressure regulator on the line of the pressure exceeds 30 PSI.
1/23/2018 5:01:53 AM • Whirlpool... • Answered on Jan 23, 2018
Whirlpool conquest fridge; freezer isn't working
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
1/2/2018 2:16:28 PM • Whirlpool... • Answered on Jan 02, 2018
Whirlpool 10 cu. ft. Chest Freezer EH101FXR Logo
9 questions posted
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Freezers
  • Whirlpool Freezers
Most Popular Question
whirlpool freezer display flashing 1
  • Freezers
