I keep getting "The page cannot bee displayed" prompt when attempting to access the internet. I've gone into device manager and updated net adapter.
You need to be sure that your network settings are properly set. If you're behind a router, make sure that your computer is in the same network with it. Ping any website like google.com and see the result by entering this command in command prompt: ping google.com. Here is a picture showing what you should see if everything is ok.
If your result is something like "Destination host unreachable" or "request timed out" try this command: ping 173.194.66.103.If you have ping with the second command - you should fix your DNS input in Network settings. Usually for DNS server you should use the IP address of your router.If you have ping in both scenarios - you should check Internet Options of your Browser. Make sure you have entered proxy settings if you're using one. Make this initial diagnostic and write about the results so that I could help you.
