it is not any kind of car or truck,so moved you to portable elect gas generators.
does it burn gas/petrol or LPG?
with engine stalled, oil lamp on is 100% normal
but never at the time of stall (or just before)
the oil pump runs off the crankshaft is why.
new spark plug is cure. i bet.
or use chock longer.
carb, gasoline , petrol.
if spark tip is in raw fuel , turn off chock and crank it dry.
the gen has many buttons switches make sure all are set correct for sure on./off .
is it elect starter or hand cord cranked or both?
TO MIX THE FUELSee Figure 3.? The product is powered by a 2-stroke engine and requires pre-mixing petrol with2-stroke oil. Pre-mix unleaded petrol and 2-stroke engine oil in a clean containerapproved for petrol.? The engine is certified to operate on unleaded petrol intended for automotive usewith an octane rating of 91 ([R+M]/2) or higher.? Do not use any type of pre-mixed petrol/oil from fuel service stations, such asthe pre-mixed petrol/oil intended for use in mopeds, motorcycles, etc. Do not useautomotive oil or 2-stroke outboard oil.? Use only synthetic 2-stroke oil.? Mix 2% of synthetic 2-stroke oil into the petrol. This is a 50:1 ratio
You have not specified the make and model of the genset. Usually the normal type oil used for petrol /diesel engines can be used typically the grade 40. Please look up on the manual to be more specific.
I i am not wrong you are asking about adding oil to the petrol tank. you should not add oil in petrol tank for any 4 stroke engines yours is 4 stroke. engine oil will act as a lubricant to the piston.No need to add oil with petrol for Honda Activa.
