charles fedie Posted on Nov 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a vintage technics receiver, model numbe 5360. i would like to the watts per chanel.
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Nov 11, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2768082
Points
24828
Full specs. But take them with as grain of salt because they don't specify the bandwidth or distortion, plus they use 4-ohms as the load instead of the 8-ohm standard. Avoid driving any amplifier harder than it is designed to go because distortion rises rapidly and it WILL kill itself or the speakers if overdriven.
http://www.classic-audio.com/technics-sa5360-p-357.html
1helpful
Compatibilty
If what you say is true, you should be fine.
Where you get into trouble is having an amp of higher power than your speakers. That means you will likely blow your speakers.
How many watts per channel in a technical pro 1500 reciever?
Is that the RX113, or some other? The 1500 is informative, being peak power total. This is about 375 Watts/channel RMS, which is enough to blast the neighbours anytme.
Klh model 20 no volume
what kind of speakers do you have hooked up? make sure your cables from the speakers are good. you should have an RCA type hookup on your record player, make sure they are in there good too
Can a technics su v670 be wired up with a technics power amp a800s mk II?? what im thinking it doubles up on the power the wattage to each channels? am i rite? the suv 670 is 90 watts per channel and the...
"im no proffetional at this". Really?
If you looked at the manuals for either product you would NEVER find a recommendation to use one amplifier's speaker input to drive the LINE LEVEL (very small) input on another amplifier. Speaker outputs are for driving speakers or amplifiers designed to accept speaker-level input (like some self-powered subwoofers). In no case is the power of the originating amplifer BOOSTING the power of the driven one.
You should do some reading on how amplifiers work before you blow something up and come asking for advice on how to resolve it.
2answers
Power out rms- 4 o 8 homs?
I can see why you're asking for help on this. It almost seem this unit has been 'disappeared' as far as online information is concerned. Even Sony has nothing on it.
I founs some articles and For Sale posts:
http://toronto.kijiji.ca/c-buy-and-sell-electronics-Sony-STR-4800SD-Stereo-Receiver-135-OBO-W0QQAdIdZ243602516
"Sony's STR-4800SD receiver was extensively, and positively, reviewed in Stereo magazine's Fall '77 issue. In their introduction, they found the 4800SD bettered its published f.m. sensitivity specs "by a wide margin...it has exceptionally smooth frequency response, very low distortion(especially in the midband), and excellent quieting. No exotic claims are made for the power amp section, either (35 watts/channel,15.4 dBw at 0.2% THD). But our tests indicate much more capability than that, and a distortion of only one-tenth that spec."
The power consumption figure shown in a photo below says "145W", which would be consistent with a 35 watt amplifier.
http://www.oaktreevintage.com/web_photos/Stereo_Receivers/Sony_STR-4800SD_Stereo_Reciever_collage.jpg
Will 12 watts run these speakers? I'm thinking of buying a vintage Panasonic RA-6600 Receiver and read it only has 12 watts per channel. Thanks George
No, furthermore, UNDER-powered amps are more dangerous to speakers than over-powered ones since they begin to distort badly at much lower power outputs. Distortion kills speakers.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
