Watches Logo
Posted on Nov 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set time on GPS watch
Just failed to set time back in Indiana
Anonymous
Level 2:
Sergeant:
  • Expert 302 Answers
  • Posted on Nov 07, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
302
Questions
Helped
154837
Points
531
From your comment I have no idea what watch you have! The more infromation you provide, the likelier it is we will have a solution. However, in general, watches cannot tell if you live in a spot on the globe that uses daylight savings time. You have to enter that information. Go into your settings and see if you can turn on Daylight Savings. The watch should set the time automatically at some point, occasionally takes some time. Only a part of the world uses daylight savings, invented by Ben Franklin to save energy(coal oil) just like today!
Where can I get instruction details for my POD 550 watch?
RCX5 found it surprisingly light and small. It doesn't look like a computer on your wrist like many other GPS watches. Of course that is largely because the bulk of the GPS components and battery are in an arm band.
The armband and separate GPS device seemed like, and became, one extra piece of equipment to worry about.
The watch, heart rate monitor and foot pod all use watch batteries. Battery removal can be difficult, however once the back is removed the batteries are easy to install and replace. The GPS piece is charged with a standard USB cable.
The speed and cadence sensors batteries are not replaceable. These sensors must be purchased again when they wear out
The speed and cadence sensors are attached to a bike with zip ties. I found them easier to install than the Garmin sensor largely because they are separate devices. It was easier to position each of them so that they picked up the magnet from the wheel/pedal separately, rather than trying to align one device to detect both.
Additionally the speed and cadence sensor each have a built in led light that flashes each pass of the magnet.
However, to configure your stride length is tricky at best. The best way to do it is to run a distance using the stride sensor that you know the actual distance of, then change the distance in the history. So let's say you ran 1 mile. The watch believes you ran 1.1 miles. By changing the history to 1 it should adjust the settings so that the next mile you run will record correctly.
Once you have been using the watch for some time you can get into advanced setup. You can add your own sports, or configure the devices, and screens setup with each sport.
You can do this from the watch, but it is easier to do it from the Polar Web Sync software. The software works much like a remote terminal for the watch. You connect to the watch and add or change each sport profile, or change user or device settings.
May 09, 2015 • Watches
Waveceptor reset
I have a number of these Casio and Citizen watches. This watch does not use GPS for the time keeping. It uses a land based broadcast time signal. There is public information about where the signals come from for your area. The technical breakdown of the time code signal is public access information.
The instruction manual of the watch has the information about when your watch should automatically receive the time signal, and how to set up the watch. Many of the manuals also included a map showing the time signal coverage, and includes the time of day information to show when the signal is strongest.
Make sure the watch settings are for your time zone. This is important. If the main time zone is not for your area it will be trying to receive the signal at the wrong frequency at the wrong time of day. There are areas where the signal may not be able to be received. You can get the mapping for this from the service that the watch has been set to use.
In North America the auto time receive is supposed to take place between midnight 00:00 to 04:00. In the eastern part of North America the reception is poor compared to central and western part of North America. Check the instruction manual for your watch for details.
Below is the spec listing of your watch.
  • Atomic Timekeeping
    Receives time calibration radio signals which keep the displayed time accurate
    Auto receive function (3 times per day)
    Manual receive function
    Signal: WWVB, UK MSF Frequency: 60kHz
  • 50M Water Resistant
  • EL Backlight with Afterglow
  • World Time
    29 times zones (30 cities), city code display, daylight saving auto/on/off
  • Date Alert
    Display flashes when set date is reached
  • 4 Daily Alarms and 1 Snooze Alarm
  • 1/100 second digital stopwatch
    Measuring capacity: 99:59'59.99"
    Measuring modes: Elapsed time, lap time, split time, 1st-2nd place times
  • Hourly Time Signal
  • Auto Calendar (pre-programmed until the year 2039)
  • 12/24 Hour Formats
  • Accuracy: +/-20 seconds per month (with no signal calibration)
  • Battery CR1620
  • Approx. battery life: 2 years
  • Module 2556
Size of case / total weight
WV57 47.0 x 39.0 x 12.5mm / 44g
WV57HD 47.0 x 39.0 x 12.5mm / 89g
How do i set my settings to record the distance on my nb gps runner
On my new NB Runner GPS watch, how do I set the setting back to zero each time so I know how far I have gone ?
The problem I have with it is that the next day when I turn on the run mode it shows the previous day numbers.
Please help i cant set the time on my timex ironman triathlon gps body link watch M229
Hi ianloggie,
Goto this link and select the model of your watch to download instructions on setting time...http://www.timex.com/info/Product_Instruction_Guides_Downloads
please vote and rate me if i solved your problem :)
Regards,
Salman
I have an Ironman GPS trainer, and the date and time is set by the GPS info you enter into it. I am in US-Pacific time zone, but the watch shows AM instead of PM, and is displaying a date no where near...
Hello bzgoodsbl,
When I encounter a product such as your
Timex 5E681... Knowing absolutely nothing
about modern TIMEX or ...
But being an ACCOMPLISHED amateur horologist
(clock, watch, licensed radioman and admirer of John Harrison)...
https://en.wikipedia.org/wiki/John_Harrison
>> I looked your "IRONMAN" up...
- inexpensive (Amazon)
- Very Popular 4/5 STARs
- Easy to read instructions
Just my own observation here:
Before I would hand any TIMEPIECE I ever
cared about... over to some PIZZA-FACED
**** at the corner **** store...
I would seriously consider spending a few dollarson some WATHMAKERS tools and opening
the device myself...
As soon as AN UNAUTHORIZED person opens
your "IRONMAN" the warranty is VOID.
Just know your options.
NEW = Send it back (do it now).
https://www.timex.com/returns-exchanges.html
7helpful
2answers
I need a manual for my casio wave receptor
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
Top Citizen Watches Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Citizen Watch Expert? Answer questions, earn points and help others
