20 Most Recent
Citizen Campanola Perpetual Calendar AG6210 03E AG6200 Watch for Men Questions & Answers
Need an expert on the
in order to set the repeater chime you need to set the watch and the sub watch to the same time.
This watch has comes with crown in position 0 , if you pull it out one level it becomes position 1 and if you pull it out one more time it is position 2 .
There are 3 buttons on the watch also. The button directly above the crown is button A the button below the crown is button B and the button directly across the crown is button C.
To set time you must first pull out crown to position 2 when the small second hand is at 12 o'clock position and it is stopped.
The mode will also at this time go to 0 and the sub watch second hand( the long second hand with the sun on it ) will also go to 0.
At this time you can just move the crown to set the proper time to the main watch . Now if you press the B button to set the sub watch . Each time you press the B button it will advance one minute hold down the B button and will advance time faster.
Do this to set the sub watch time make sure you watch the am and pm to make sure you are getting the proper time of day.
if the sub watch second hand ( the long second hand) is not aligned to 12 oclock then press the A button keep pressing button or hold it down to go faster until it is aligned at the 12 oclock position
Now push crown in back to 0 position for your time for your watch and sub watch should be set.
Set leap year.
Pull crown to position 1
Press the B button to adjust leap year.
the leap year is set by how many years from the previous leap year it has been . So 2008 was the previous leap year so we will h ave to set leap year at year 2 . The hands of the leap year are connected to the month so you must hold down a and b button or just press the b button to get to year 2 .
once you do that your leap year should be set.
to set the Repeater ( this is a beep from the watch to tell you the time with sound) make sure crown is in 0 position and hold a button for a couple of seconds to activate Reapter.
you can press any other button to end the chime .
also to get to leap year view while crown is in 0 position hold down the b button for 2 seconds . Pushes any button to return to normal calendar.
12/27/2010 10:23:52 AM •
Citizen...
Answered
on Dec 27, 2010
Citizen eco-drive wr 200 manual
I'll need more information about the watch. WR200 is not the model number. It is the depth in metres it is water resistant to.
The serial number is usually engraved on the back plate of the watch. The bit against your skin when you're wearing it. It's the number marked in red in the photo I've attached. Is this a digital watch, a watch with hands or does it have both?
Comment below with the serial number and I'll try to help you more.
I have an old Citizen
hi, I'm from Italy and changed the batteries just 2 days ago - theer are three batteries inside this watch - in a normal shop selling citizen watches.....
I think youhave just to change shop....
I m having a citizen sailhawk c660 ecodrive promaster, due to pandemic I didn't wear it for 4 months, now it stop working, previously totally digital display gone but after some time digital display flashes as UTC at right and 01/01, TUE at left, after putting it at chr. Plus pulling out the crown, I pressed all three buttons simultaneously, which shows complete blank now for digital display moreover second, hour , minute hand are also not moving at all.... can any body help me rectify it PLZZ...
is it the battery, batteries are usually always the problem
How do i set time on radio controlled wrist watch 3 atm
The point of a radio-controlled watch is that you should not have to move the hands manually. It is meant to respond to a time signal send from various places in the USA, UK, Germany, Japan and (I think) China.
The signal's strength varies considerably, depending on where you are located and the ambient temperature. It may need some application and persistence to get the watch synchronized with the signal, this will cause the hands to move to the correct local time - even then it may need correction if you are in a different UTC time zone or on Daylight Saving Time (DST) locally. Not knowing the make complicates the validity of any information.
I have found that the sync signal is broadcast on the hour for about five minutes and is best received at night where the signal travels further.
Ensure your watch is fully charged and leave your watch by a window overnight for best results.
If you still have difficulty, use an internet search to find the nearest broadcast station to where you are and work out which direction-facing window is best sited to face it.
I have two RC watches - one Citizen and one Casio. One likes to have the left side of the watch facing the window and the other favours the 12 o'clock facing the window, As I don't know the make of your watch I would recommend trying to place it in various orientations until you find one that works for you. I have found the whole set up performs best in cold air situations - and so are more reliable in the winter.
Guessing further, If you bring up the signal display function it may force the watch into signal sync mode - always remembering the 'on the hour' signal broadcasts. You may also find a way of adjusting the hour to suit if it differs for you once it is synced.
