SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
SOURCE: indesit condenser tumble dryer water
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
SOURCE: Tumble Dryer not getting hot
thermister i.e thermostat in located just in side of fillter housinfg damaged replace i
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these
This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
