20 Most Recent AEG T58840 Dryer Electric Questions & Answers
0answers
Drum goes round, only cold air circulating and no heat to dry washing, machine is constantly bleeping and signalling end of drying cycle
If you pull the panels off you should find the tech sheet to help diagnose your machine. But in you case sounds like it need to be taken apart and cleaned and check the limit switches.
12/4/2015 5:01:29 PM • AEG T58840 Dryer... • Answered on Dec 04, 2015
How do you get it on to spin as i have just put a new one bought today o a cycle and it wont spin.
Ok I believe your referring to a washer machine. But I would suggest to review user manual, and if all else fails I would call in for service, cause your machine is still under warranty.
12/4/2015 4:53:43 PM • AEG T58840 Dryer... • Answered on Dec 04, 2015
HOW TO CHANGE CONDENSOR ON SKODA OCTAVIA 2008
What condenser are you talking about, cause it's sound like your talking about a refrigerator.
12/4/2015 4:23:41 PM • AEG T58840 Dryer... • Answered on Dec 04, 2015
Tumble dryer keeps stopping and showing E50
E51 - Motor power triac short-circuited. E52 - Intervention of motor overheating safety cut-out. E53 - Motor triac "sensing" circuit faulty. E54 - Motor inoperational. Dado
10/20/2015 12:43:46 PM • AEG T58840 Dryer... • Answered on Oct 20, 2015
E60 aeg 37840
E61 - Insufficient heating (maximum time exceeded) E62 - Power relay to heater unit faulty E63 - Intervention of auto-reset thermostat on the heater unit. 23830107-3rcfyex5vwz3ubyzzwgflfev-1-0.jpg Dado
10/20/2015 12:29:04 PM • AEG T58840 Dryer... • Answered on Oct 20, 2015
Error E60 dryer
E61 - Insufficient heating (maximum time exceeded) E62 - Power relay to heater unit faulty E63 - Intervention of auto-reset thermostat on the heater unit. E64 - Heater thermostat. E65 - Fan motor triac faulty. E66 - Fan motor thermal protection. E67 - Triac control faulty. Dado
10/20/2015 9:14:22 AM • AEG T58840 Dryer... • Answered on Oct 20, 2015
Tumble dryer isblowing cold air only?
Your dryer is called smart dryer and in this case should have to generate familiy code E60 (or any of exactly fault code E61,62,63,64,65,66,67) if blowing cold air, as you explain. Means something is wrong with heating phase (drying). So, in this case could be: Heater unit faulty; Wiring faulty; NTC sensor faulty/out of position; Electronic board faulty; Thermostat faulty; and finally fun motor - but considering that it blows cool air I guess that is correct. 24642590-hf2jxxovvq5cn05mugly0fcq-2-0.jpg Dado
10/16/2015 6:40:23 PM • AEG T58840 Dryer... • Answered on Oct 16, 2015
No heat
There are many things that could be wrong. On most machines there is an electrical diagram somewhere inside or on the back of the cabinet. You can check each item in the heater circuit until you find the faulty item. On most dryers it is the "over heat" fuse link that goes first, but there are MANY other possibilities. First thing.... make certain all switches are in the correct position, not half pressed in or 2 pressed at once. I hope this is helpful.
7/19/2014 4:07:36 AM • AEG T58840 Dryer... • Answered on Jul 19, 2014
0answers
Our tumble dryer is not
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
8/24/2011 12:58:57 PM • AEG T58840 Dryer... • Answered on Aug 24, 2011
AEG T58840 Dryer Electric Logo
43 questions posted
Top AEG Dryers Experts
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
David Spradling
David Spradling
Are you an AEG Dryer Expert? Answer questions, earn points and help others
View Most Popular
AEG Dryers
  • AEG Dryers
Most Popular Question
indest 7kg tumble dryer barrel
  • Dryers
