Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Controlling Color Density
When colors look faded, adjust the toner color density to extend the life of the components.
Print and use the Color Reference Page 1 In the printer's front panel, scroll to Calibrate Colors,
press Menu and print the Color Reference Page. 2 Compare the Color Reference Page to the Color Density
Samples on page 39. Make a note of the value (-10 to +10) for each color that most closely matches the samples.
3 Adjust the density for each color: Enter the value noted in Step 2 in the Calibrate Colors menu, under Adjust Each Color.
? Decrease color density: Press . ? Increase color density: Press --->.
4 Reprint the Color Reference Page; check your adjustments
