20 Most Recent Sharp Aquos LC-45GD4U 45 in. LCD HDTV Questions & Answers
2answers
32
i had the same problem in a sharp tv 32". on the remote control there was a view mode button, i changed the mode and the pc input label in the left upper corner gone
11/20/2022 7:33:35 AM • Sharp Aquos... • Answered on Nov 20, 2022
2answers
Aquos LC37D40U Blinking light and won't turn on
The power light is an error code that tells me exactly what is wrong with the TV. Count how many times the POWER led flashes per second? (Dont worry about the OPC led)
1x per second (constant steady blink) = bad inverters/lamps
2x per second = bad power supply
3x per second = bad main board
If its 1x per second, try doing the factory initialization to get the TV back on to confirm a bad lamp/inverter.
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go.
Once the TV turns on, take a look at the screen. Does it flicker then shut off? Or do you hear a buzzing noise from the right edge of the TV? If so, then you have bad inverters or lamps. Once youre done, unplug the tv to get it out of the service menu.
If it is 2x per second or 3x per second, then those boards are just bad and they need to be replaced. There isnt anything you can do right now to fix it.
1/21/2019 5:29:19 PM • Sharp Aquos... • Answered on Jan 21, 2019
I have a 70 inch sharp aquos tv. the picture was too big and didn't show the whole scene. i tried to reset it, but somehow i need to redo the whole set up. i use dish network, so i don't rem
Does your remote for the dish have an aspect ratio setting on it?...if it does change it to normal
1/6/2018 10:00:13 PM • Sharp Aquos... • Answered on Jan 06, 2018
2answers
How do I reset the secret code for a lcd Sharpe
Factory Default Reset:
- Unplug the TV and count to 10 slowly.
- Hold down the power button on the TV (not the remote.)
- Plug in the TV while holding power button.
- Count to 10 and release the power button.
- Turn it on and hope for the best.
12/2/2017 2:05:54 PM • Sharp Aquos... • Answered on Dec 02, 2017
Sharp remote quit working. Lights turn on, could it be the tv's problem? Ga724wjsa
Another way to verify if the remote is working is use your phone or camera to look at the IR eye of the remote while pressing a button you will be able to see a red light everytime you push the buttons to make sure the remote isnt just faulty. For any Sharp TV do it yourself TV repair call us in Centennial, Colorado.
12/8/2015 4:47:05 AM • Sharp Aquos... • Answered on Dec 08, 2015
How to get the stand by red light to stop blinking as it does not respond to remote?
Have you tried to see if you can put the unit into service mode? (power button, input select and volume down). Don't select anything from the menus, just see if you get an error code.
9/27/2015 5:45:17 PM • Sharp Aquos... • Answered on Sep 27, 2015
LC45gx6u power wont stay on turns off
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
5/22/2015 3:14:06 AM • Sharp Aquos... • Answered on May 22, 2015
What's the difference between an LCD tv and an LED tv
LCD stands for liquid crystal display. A led tv uses pixel sized leds to make the picture.
12/31/2014 5:26:59 AM • Sharp Aquos... • Answered on Dec 31, 2014
Reset sharp
You have to enter its service mode option, to make it a factory reset. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
8/1/2014 2:09:48 PM • Sharp Aquos... • Answered on Aug 01, 2014
0answers
0answers
No sound
check the p-touch
4/21/2014 10:08:20 AM • Sharp Aquos... • Answered on Apr 21, 2014
Green screen
A bad symptom indeed. Contact the authorized service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCD screens are given. You can compare it to that of your TVs' and can make sure about the fault.
3/7/2014 1:55:48 PM • Sharp Aquos... • Answered on Mar 07, 2014
The heatsink patty melt it off I need more of that
There should be some overload to your TV. Might be of shorted component/s at its other boards, than the main power regulator board. The troubleshooting is somewhat skilled one. It will be best to contact any service technician. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
11/2/2013 12:49:37 PM • Sharp Aquos... • Answered on Nov 02, 2013
Need to program an old awa 5-in-1 universal remote
094,092,097,091 are the codes to check. If you wish to get more, check these links. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
10/5/2013 3:56:06 PM • Sharp Aquos... • Answered on Oct 05, 2013
Sharp Aquos LC-45GD4U 45 in. LCD HDTV Logo
103 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
lc45gx6u power wont stay turns off
  • Televison & Video
