20 Most Recent
Mitsubishi WS-65611 65" Rear Projection Television Questions & Answers
My tv turns on the shuts off on its own
This unit will not indicate any problem without you doing something to initiate the LED diagnostic feature. Go to the front of the set and hit the power button, when that doesn't work hold the MENU and INPUT buttons on the set at the same time for 10 seconds. The power LED should start blinking a two sequence code that will repeat six times. The number of blinks will tell the general area of the problem. As an example a 2 - 2 sequence is a convergence output problem over 95% of the time.
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.Let me know what error code is found and I will tell you what it means.SD TECH
Blue colors are turning green
For model listed here, a issue likely on the Blue CRT circuit board, bad grounds and even seen a tiny crack on that board do this, sounds like blue is dropping out.
Ws-65611 color shadows
You need to turn down the voltage on all 3 crt's. You have a red one, a blue one and a green one. Slowly adjust the knob down until you don't see the shadow any more. Then adjust your color in the user menu.
How to reset factory settings ws 65517
If you contact Mitsubishi the set has three hidden menus---convergence adjust, circuit adjust and OPTION MENU.Each model uses a four digit code with menu and for example 4750 and in the Option menu is the option to do the hard reset for the set---The wipes all labels (dvd etc) and puts set back to default on all factory settings.You might find it if you GOOGLE THE MODEL NUMBER with option menu after it...........
