Kenmore 98702 Stacked Washer/Dryer Logo
Mary Singleton Posted on Oct 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto floor.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 23, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
448
Points
I have a Kenmore stacked washer and dryer. The water won't drain. I was able to empty it by attaching my shop vac to the hose. Lint came out and we drained water by the shop vac. Added water to the washing machine and tried to let it drain through the spin cycle. Did this severalimes and it still won't drain. Have can Iremove the backpanel?
Dan Webster
Level 3:
  • Kenmore Master 8,221 Answers
  • Posted on Nov 11, 2011
Dan Webster
Kenmore Master
Level 3:
Answers
8221
Questions
5
Helped
2381216
Points
25840
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
98702 Stacked Washer / Dryer Your question about - 11_11_2011_5_19_32_pm.jpg11_11_2011_5_20_23_pm.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mom has a Kenmore stackable washer. She ran water into the washer and all the water came out on the floor.
This seems like a difficult problem but is an easy fix. Remove the hose from the water level switch and blow out the sediment like this:
Service manual and more photos HERE
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
1helpful
Stackable softener dispenser stays filled with
if its the dispensor on top of the adjitator it snaps off then you can unscrew some of them to clean. or just soak it in hot water.good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
3helpful
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Washer leaking water, flooded my apt. this is a kenmore stackable. how can i fix it?
I know it needs a new pump, but I can't find the model number of the unit anywhere.
1helpful
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Alexander
vince
