This motherboard's full name is ASUS M2N78-LA and also used from HP/Compaq with the name: Viola-GL8E. A good replacement solution for this board is Zotac GF8200-C-E GeForce 8200-ITX WiFi AM2 DDR2-1066 (about 130$). Here are some links for this board: from Nvidia for specs and from Amazon. Take care that the original board is micro ATX factor and the suggested one is ATX factor, so you may have to check the available space in the tower.
Stelios
SOURCE: The drives are not recognized
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including
electrical extensions, DE,SATA the leads from your ((motherboard to your hard drive)) make
sure they have a secure connection and are not faulty or just replace them they
might be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs all electrical power and data to travel through every working device its and
have an end so any faulty leads will end up with a computer error
make sure your ram and cmos battery are securely seated with no dust in sockets
During the boot process you
will see on the screen to press delete to enter setup
Press
and hold delete during the boot up process to enter BIOS
hope
this will help
might be faulty
Press
hope
this will help
