Texas Instruments BA-II Plus Calculator Logo
Anonymous Posted on Oct 17, 2011
Suppose that the current one-year rate (one-year spot rate) and expected one-year T-bill rates over the following three years (i.e., years 2, 3, and 4, respectively) are as follows: 1R1 = 6 %, E(2r1) = 7 %, E(3r1) = 7.5 % E(4r1) = 7.85 %
Lammert Raan
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 31, 2014
Lammert Raan
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
907
Points
1 Related Answer
  • 102366 Answers
  • Posted on Nov 26, 2010
SOURCE: PV and FV problem, result not like in manual
You have the payments-per-year set to 12. For this pair of problems, it needs to be set to 1.
Press 2nd [P/Y] 1 ENTER.
Have an older Sharp EL-1801Piii. I need to program a tax rate of .08917. How do I do that?
Here is the manual link
Press CTRL+F Type in 'tax' top right, press Enter. Scroll through the 19 mentions, Number 3 shows it. Copied and pasted below, but it doesn't show symbol image. The first paragraph covers getting into setting mode and setting date and time, then comes 'Tax Rate'.
https://www.manuallib.com/download//SHARP-EL-1801PIII-OPERATION-MANUAL.PDF
GT • RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR: "GT": Grand Total "•": Neutral "RATE SET": To set the date, time, and tax rate, set this switch at the "RATE SET" position. Date: • Enter in the order of month, day and year, then press to complete the entry. • Use to separate month, day, and year. • When is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: • Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) • If the hour/minute digit is less than 10, it is not necessary to enter the first digit "0". • Use to separate hour and minute values. • When is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Tax rate: • Press three times, enter the tax rate, followed by . • A maximum of 4 digits can be stored (decimal point is not counted as a digit). • Only one rate can be stored. If you enter a new rate, the previous rate will be cleared.
more here and videos
https://www.google.com/search?q=sharp+el-1801piii+set+tax+rate
The following problem is not difficult, however, I am having trouble calculating the answer using my HP 12c Platinum. Can you please provide a step by step explantation of how to calculate the answer to...
1. Make sure the HP-12C is in compounding mode. Press STO-EEX repeatedly until a tiny "C" appears in lower right of display.
2. Make sure "BEGIN" is NOT shown in the display. If it is, press g-END.
3. Clear financial registers: f-FIN. (That is really the "f" key then kind of the "Clear FIN" key -- I'm sure you'll see it.)
4. Enter zero as "initial investment". CLx, then g-CF0. (You have to do this because the 12C actually computes the "NPV" as an excess or deficit over the entered "initial investment". By entering zero, you force the calculator to just give you the actual net present value.)
5. Your first cash flow is +2.00. So, enter 2.00, then press g-CFj.
6. Next cash flow: +2.10. Enter 2.1, then press g-CFj.
7. Last cash flow: +22.20 (the final value of the stock plus the last dividend payment). Enter 22.20, then press g-CFj.
8. Enter the 10% interest (a.k.a. discount) rate. Enter 10, then press "i".
9. Compute the NPV. Press g-NPV. The answer is indeed 20.23 (at least to two decimal places).
1helpful
I have a holiday timer LW28080. Following instructions to the letter the unit did not go on at the set time. The manual works but not the timer. Does the time actually have to start on the first day...
LW28080 is NCC brand digital power center.
Copy following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#0050024
Programming should start on the day you selected for Program 1 ON. So if Tues was selected, timer should start Tuesday.
Use paper clip, and push in Reset button for 2 seconds. Repeat. Always reset digital timers before programming to clear memory glitches.
Plug timer in for 10 minutes to charge battery.
Be sure to set current time with correct day, hour am-pm and minute.
Each ON program requires OFF program
Set program 1 ON and then set program 1 OFF.
Make sure selected day(s) of operation match for both ON and OFF settings.
Check am-pm conflicts in programming.
Avoid 12:00, to avoid am-pm confusion. Use 12:01 or 11:59
Avoid programming overlaps and conflicts that cause timer not to function as expected.
When programming is finished, press current time button to return to current time.
It appears timer is ready for programmed operation at this point.
Install Mi-MH battery that comes with timer.
Do not exceed watt rating.
This timer comes with 1 year limited warranty and can be expected to last 1 or 2 seasons, and probably quit season 3.
1-800-730-3707
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Need 2 add more mem
Hi BBrown,
There is an excellent step-by-step guide here
http://www.computermemoryupgrade.net/installing-laptop-memory.html
However, you NEED to find out what exact model of Gateway laptop you have to make sure that the RAM modules that you buy will work with your laptop since there are physical limitations to make sure you don't install the incorrect types.
For example, there's SDRAM (associated with Pentium III laptops from 10 years ago) and three generations of Dual Data-Rate memory (DDR for short).
DDR3 would be used in current laptops (maybe up to 2 years old), DDR2 (2-6 years old) and of course, Pentium4 era DDR as well,
Hope the helps
-BuzzPuppy
1helpful
I have a fuse problem it went out after 2 years and put a new 1 in it lasted 5 mo. anouther new 1 it lasted three weeks. Can i put in a stronger fuse?
If a fuse is blowing, it's usually caused by a short somewhere and is intended to prevent further damage or a potential electrical fire. It's generally safe to use a fuse rated for ~10% more current, but if it still blows out, I'd recommend taking it in for service. A higher rated fuse will have no bearing on the normal operation of the TV.
1helpful
I need to calculate NPV for the following: beginning of year payments of 15,700 / 4 years / 9% borrowing rate. I was told the answer is 55,441.33, but that's not what my calculator gives me. What am I...
Did you take into account that you have beginning of the year payements? Your calculator probably treats it as an end-of-the-year payment? Did you try treating the first payement as an initial cash flow (should be available as an option in your calculator input) and the treat the three remaining years as end of the year payements at your 9% rate. It should do it.
1helpful
Low Heat from GE XL44 gas range
you can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
