20 Most Recent GE Spectra JGBP35 Gas Kitchen Range Questions & Answers
2answers
GE electric range oven will not heat?
Its your oven igniter that's bad. The oven igniter connections are underneath the oven. To get access to the oven igniter glow bar electrical connector, I take out the bottom storage drawer completely then get a flashlight or floodlight to see under there, and then I can see the oven igniter glow bar connector. Its easy to replace, just take the bottom oven panel from inside your oven off, then you remove the flame spreader metal shield, then you will see the oven igniter mounted on your burner tube, just remove the oven igniter off from your burner tube and install the new one. Unplug your range first before changing it. Here's the oven igniter for your model you can order: Igniter WB13K21 Order now for same day shipping. 365 day return policy. RepairClinic.com Appliance Repair Forums
2/3/2018 3:18:13 PM • GE Spectra... • Answered on Feb 03, 2018
GE Spectra XL44 Model# JGBP35DED4BB
Oven sensor or thermostat most likely bad
1/2/2018 3:31:53 AM • GE Spectra... • Answered on Jan 02, 2018
2answers
I smell gas and my burners wont light - is there a...
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
1/5/2016 9:35:53 AM • GE Spectra... • Answered on Jan 05, 2016
3answers
Www.ge.net How to get rid of flashing lock door on JGBP35
There is a button on the left upper corner by the door when you open oven. Hold the button down and press the clear button on the panel till the display clears itself. Just like that you have a functional oven.
11/14/2014 5:14:04 AM • GE Spectra... • Answered on Nov 14, 2014
What causes a loud bang from oven?
If you hear a loud bang the SECOND time you try to light an oven, it means you've just had a small explosion when the gas from the FIRST try ignited outside the heating tube. I would have a professional check your oven before using it again.
7/18/2014 10:25:20 PM • GE Spectra... • Answered on Jul 18, 2014
0answers
Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
11/3/2013 4:14:13 PM • GE Spectra... • Answered on Nov 03, 2013
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
10/23/2013 2:33:19 AM • GE Spectra... • Answered on Oct 23, 2013
Oven's bake funktion does not work
Hi,You need to replace the oven igniter. You will find that this is a very common problem with that model and other models that use this igniter. It is very simple to do.
Look inside the oven and you will find 2 screws at the bottom of the oven in the back. Loosen them up and remove the bottom panel of the oven.
Remove the broiler, and oven trays and it is a 10 minute swap out. Removing the above items allows you the access needed to get to the two screws that mount the oven igniter to the burner.
Using either a socket (1/4") or a nut driver, remove the 2 screws and unplug the igniter. The most difficult part of the exchange is unplugging the igniter. The plastic will most likely break because it has become very brittle by being exposed to the heat. Be careful to break only the part that is being replaced.
If you do happen to break the fittings, they can be replaced with any male/female connector. If you need to replace this, I recommend that you stay away from plastic encased plugs.
You then install the ingiter, plug it in, and you are back in business. It is a very simple part to replace, but it is costly.
Thanks and take care
5/7/2013 1:37:19 AM • GE Spectra... • Answered on May 07, 2013
F 1 COMES UP ON
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
3/20/2013 10:49:09 PM • GE Spectra... • Answered on Mar 20, 2013
The oven heats but not the right temperature
probably need to replaceyour tempature control unit if the heating element turns red when you turn it on. Phil Anderson
9/23/2012 3:31:21 PM • GE Spectra... • Answered on Sep 23, 2012
GE Spectra JGBP35 Gas Kitchen Range Logo
137 questions posted
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
GE Kitchen Ranges
  • GE Kitchen Ranges
Most Popular Question
oven heats but not right temperature
  • Kitchen Ranges
