20 Most Recent Vizio P50HDTV20A 50 in. Plasma HDTV Questions & Answers
Power and display
Circuit board capacitor failure
10/29/2020 3:05:23 AM • Vizio P50HDTV20A... • Answered on Oct 29, 2020
I have a 50'vizio HDTV 20A, the tv was flashing
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
6/14/2017 2:51:53 PM • Vizio P50HDTV20A... • Answered on Jun 14, 2017
Yes it does turn on . but no pitcher
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
4/10/2016 3:42:42 PM • Vizio P50HDTV20A... • Answered on Apr 10, 2016
0answers
Have picture, but why no sound?
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1/2/2016 3:33:43 AM • Vizio P50HDTV20A... • Answered on Jan 02, 2016
2answers
I have a five year old Vizio P50HDTV20. While
Sorry the problems,ur tv it is having,it can't be repair,the tv Plasma screen panel itself it is shorted and dead,that why the tv plasma screen panel have only a third of the plasma screen panel it have a good clear picture and the other 1/3 of the tv plama screen panel is black and dead.The tv that have a broken or shorted dead plasma screen panel it is not worth repairing,because only way repair it is by replacing the whole entire plasma screen panel itself.The tv plasma screen are about 90% of the cost of the tv and can't buy it anywhere else except the tv corporations dealers themselves.Sorry tv now,only can be salvages for those electronic boards for parts that it.
1/25/2015 7:40:37 PM • Vizio P50HDTV20A... • Answered on Jan 25, 2015
Why does my Vizio 50" plasma tv not capture the video signal? It keeps poping in and out till it warms up and then it will finally hold the signal.
Be sure that your signal is strong enough coming through the HDMI or coax. If your signal is strong enough, it may actually be your TV's power supply needing to warm up.
11/25/2014 6:22:33 PM • Vizio P50HDTV20A... • Answered on Nov 25, 2014
Is there a fuse in tv
Fuse is located on the power supply board inside the TV.
11/17/2014 7:38:05 PM • Vizio P50HDTV20A... • Answered on Nov 17, 2014
No picture on tv but have audio
Your input cable is in wrong slot...switch around and it should work.
11/16/2014 3:14:19 PM • Vizio P50HDTV20A... • Answered on Nov 16, 2014
Why does my vp50 hdtv20a turns on for about five minutes and then turns itself off
sounds like you have a bad capacitor(s). my TV did the same thing, so I removed the back of the TV and looked at them and noticed (9) of them were bulged at the top ( should look flat). I am no electrician by any means but was able to replace them with a slightly higher voltage myself for around $45 instead of someone servicing it for $400
6/27/2014 9:37:37 PM • Vizio P50HDTV20A... • Answered on Jun 27, 2014
0answers
0answers
0answers
Sound but no picture
this happened to me about a week ago. It was my cable box. If you have a cable box,unplug it from the electrical socket Wait about 30 seconds and plug it back in. give the box time to gather all info and then retry the tv.
1/24/2014 10:24:28 PM • Vizio P50HDTV20A... • Answered on Jan 24, 2014
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
153 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
no sound no picture
  • Televison & Video
