Acer Aspire 5100 Notebook Logo
Posted on Sep 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
4920 Any advice would be appreciated. I have just purchased (1 day) Acer Aspire 4290.(vista) The problem is the noise level and frequency of the fan. It seems to be starting up every few minutes. I'm wondering if this is normal for a new system and if it will settle down over time. My old ASUS laptop (xp) with much lower specs has a much quietier and less frequent fan. So the comparison between the 2 is chalk and cheese. Is there anything i can do about the Acer or is this just inherent in this product - and should i just give up and send it back.
Anonymous
Level 3:
President:
  • Master 2,961 Answers
  • Posted on Sep 19, 2008
Anonymous
Master
Level 3:
President:
Answers
2961
Questions
Helped
1638466
Points
8444
No this is quite common, more so since dual core processors as they need cooling more often, you may find it even comes on when surfing the net, because there are allsorts of processes going on in the background, especially in Vista models
Your Asus was lower spec and thats why the cooling fan was less noticeable, some laptops require the fan torun 99% of the time, so enjoy your Acer, they are very reliable.
Acer 4920 randomly restarting
might not be the fix but try getting the hover and where the fan outlet is give it a good hover the fan can get blocked and this will make the cpu shut down when it gets to hot
2helpful
I own an acer aspire M5100 about 1 year old, and just recently have been noticing quite a bit of noise at startup, not a great noise either, any advice? also when i slap the back of the computer the noise...
Check fans have not came loose make sure all graphic cards and so on are tight, make sure no wires have falling into fans or are rubbing them. hope this helps in some ways.
1helpful
2answers
My acer 4920 wont turn on when using battery.. but
Make Sure Your Bettary Is In Working Condition. If Not Then Contact Acer Help Center. And Replace Your Bettary.
Acer Media Touch Buttons not working for Aspire 4920
Try to re-install the Acer media touch and update your machine's bios to its latest version. (you can download it from the acer site --> www.acer.com/support)
Free-download of Sound-card+VGA drivers
Please follow the link given below and you will find the driver download for your ''Acer Aspire 7220.''
http://komku.blogspot.com/2009/02/acer-aspire-7220-windows-xp-vista.html
1helpful
3answers
Do i need the cables for the router?
To go Wireless on your desktop Acer Aspire L3600, you should consider buying an USB Wireless Adapter. It could be any brand as long have same frequency with your Netgear (i.e 2.4 Ghz/5.8 Ghz)
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
How do I install windows vista on acer 4920
hi,
here is one helpfull link but remember backup your important data from your system before going in for reinstall
http://vistahomepremium.windowsreinstall.com/upgrade/upgradetovista.htm
if this method doesn't work let me know
Further queries are welcome
1helpful
Driver
You should be able to find all drivers under Acers website the Support Area. Just search for your laptop and you can find it there. Hope I Helped!
4920 response
I don't have any personal experience with other models, i look after 5 Acers, all are atleast 4 years old and running as good as new, if you are not happy, return it as i am on an Acer 5610 at the moment and the fan is not really noisy, different noise on different surfaces; although it cuts in and out every 2-3 or so mins.
5answers
Problem with Acer Aspire 4920 notebook
all laptops are supplied with a pre installed copy of windows and the product key will be on a genuine windows sticker on the back, unless you have no sticker, in which case you will need to purchase a copy, as nobody is likely to be able to help if you have no product key and no Vista disc
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
