I have the same problem described by ben0375. First, the printer stopped printing double-sided. So I restarted it, and the screen went blue and all it has is the on off symbol and an error message with zeros. Also, the camera light is flashing. Is this fixable or is that it? I tried all the fixes I read here that involved pressing two keys and it doesn't respond.
Thanks for your help!
SOURCE: I can't print. The printer has a blue screen with an error message: Error:0xc1ab0001.
Use the instructions below to resolve the issue by
restarting the product.
SOURCE: red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
[email protected]
SOURCE: HP 6280 INK SYSTEM FAILURE
Try This :
First check with a new set of orginal HP catridge ; if still it doesn't work then the printer needs to be replaced ; call HP if the printer is in warranty they will do it free of COST ; No. for HP is : 18004746836;
Testimonial: "It didnt work for me but thank you so much for posting the number I will call them now. ~Bre :D"
blue screen - error 0x07a74dd6 at top of blue screen
1959 lib_barracuda c at the bottom of the screen
3 lights flashing on and off
Was getting screen with gray bar moving .pushed #3,#6,#9,ok-cancel. Got a blue screen a white circle at 12 o'clock line.#s 00000020. tried unplugging LH black wrapped wire block several times. no luck.
I have HP Officejet 7410. It has the bluescreen with the number 00000020 under a circle sign and the camera light is flashing. Any hints of what to do? I diconnected the wi fi. I tried the numbers in every sequence possible. Turned it on and off. Removed the plug, plugged into different outlet. Help!
This is what i'm getting, this is harddrive printer problem and apparently can not be ever solved......major cost,,,,,better to by a new one if you on't have extra warranty on your pice...!!!
I'm angry too........
afshin
