Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on Sep 26, 2011
Kd-46wt500 sony big screen colors dont line up is projectors goin out picture on tv is blurry pic looks stretched out as well
Sonny Berry
Level 3:
  • Sony Master 8,617 Answers
  • Posted on Sep 27, 2011
Sonny Berry
Sony Master
Level 3:
Answers
8617
Questions
Helped
1723458
Points
23750
Can you verify the model number and see if its A KP46WT500 model? If so chances are just the convergence Ics ( stk 392-560 ) and pico fuses are the problem. There are 6 3.5 amp pico fuses directly beneath the heat sink fins on the D board ( where the Convergence ICs are located) Check those six pico fuses and also two 5 amp picos on the G board ( where power cord plugs in) if any of the picos on either board are open then the Convergence ICs will require replacement.
2helpful
2answers
#1 tv has black horizontal line middle of screen, fades away about 80% of the way from right to left. #2 picture is blurry and the colors stretch down in horizontal lines, then picture goes back to...
The tv board that called a T-CON board it is dying to causes these problems.All the tv pictures dots pixel codes go through this board before it show up onto the tv LCD sreen panel.This tv T-CON decodering board sit in the midle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
1helpful
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
My Sony KP-46WT500 has a yellow arc of color on the upper left side that never goes away even with plug in devices like Wii. It started about 6 months ago and has gotten worse over time. What can I do?...
Very common problems,through out the DLP tv life cycles could happen again again until end of the tv life itself.The tv have a problems known as a convergence picture problems,it is dead.Tv have any colors lines like R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes?Than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The Shop will cost u like $300-350 for parts and labors.
Sony kp-46wt500 with no red projector
all three guns red blue and green should be replaced and the flote.
cost could be from $400 to 680 in parts depending on wer you buy them. I would but the parts my self then pay the repairmen to do the install this way you dont get priced up to high in parts cost.
regards,
daniel.
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Sony Wide Screen Projection TV 46"
Can you post a picture of what the screen looks like? It could be convergence amps or a pincushion problem. The pic would help clarify the diagnosis.
2answers
Sony big screen tv, no color
focus block or neck boards on thr picture tubes
2answers
Sony TV KP-46WT500
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
2answers
Red Lines On Screen of Hitachi 43FDX01B
can we see a picture of that?? I dont understand whatyour saying about the lines.. Are they differant colors or all red and do they make the pic bow?? does the pic look or have a reddish tinge to it?? is ther too much red in the picture??? Please let us know or let us see??
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
