Computers & Internet Logo
Posted on Sep 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I'm running an AMD Phenom X4 9500 off of a Asus M2N68-LA (Narra3) board. What, if any, processor could I upgrade to on this board in order to get better speed? TIA Peter
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Sep 23, 2011
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689888
Points
8444
Narra3 supports X2 up to 5600+ up to 89 watt Socket AM2 Processor (currently AMD Athlon™ X2 6000+) AND X4 up to 9600+ up to 95 watt Socket AM2+ Processor (currently AMD Phenom™ X4 9600+)
2answers
Can you tell me if AMD Phenom X4 9550 95W works with motherboard ASUS M2V-MX? Or if just that motherboard support quadcore CPU?
go to Asus web site and get the pecs for the board. it should tell you what processors will work with the board.
1helpful
M2N68-LA (NARRA3-GL8E) Motherboard Manual - ASUS Owners User Manual
There has been a lot of confusion going on around the net. However I find the driver which should work just fine with your model. However the driver is from HP/COMPAQ and the model is M2N68-LA (Ivy8)
You can download the drivers from this link
Documentations will be available here
If you have doubts let me know.
2answers
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
1helpful
3answers
M2N68-AM PLUS does not support cpu AMD Phenom 9750
No it does not. although it says it supports sockets AM2, AM2+, and AM3 and the Phenom 9750 is an AM2+, the Phenom 9750 has a wattage requirement of 125 watts. This motherboard ONLY supports CPU's up to 95watts! You would either need to get another motherboard or another CPU (or both and make a second computer).
Side note: also keep in mind that if using this motherboard with an AM2+ CPU, it will not be able to handle 1066MHZ memory (or higher) in dual channel mode, in order to get this speed you will either have to take out the second dimm or run both dimms at 800MHZ.
Hope this helps!! (and if it does, please rate or leave comment. It will be much appreciated!!)
I have a amd phenom x4 9850 quad and computer basically says it's not compatible
Hi. If you have a processor that was supported at a later date than motherboard was manufactured, your motherboard's BIOS may require an upgrade. If that does not answer your question,p lease provide more information on what motherboard and RAM you have.
4helpful
2answers
I just bought a asus M2N68-AM SE2 mob and a amd athlon 64x2 6000 processor and it comes up this model does not suport this cpu. others have same problem. I just want to no what cpu will work. what are...
Supports: AM2+ Quad-Core CPU/AM2 CPU and 45nm Phenom? II CPU Here is the complete list; your CPU is not listed. http://usa.asus.com/product.aspx?P_ID=2UWzsrOiRbMPGYpw
3helpful
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Where do i connect the front panel MIC connectors in the motherboard
hi check this web
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01357135&lc=en&cc=us&product=3644705&dlc=en
Grand Canyon Tech
Grand Canyon Tech
