Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
Anonymous Posted on Sep 22, 2011
I have a frigidaire gallery stove.I need a temperature sensor . Model No. PFEF385JFT3.Serial No.NF82105720.Where can I get one.How much is it?I believe this stove was puchased in Canada.
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Sep 22, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636879
Points
7414
According to the Frigidaire website the place in Canada where parts can be obtained from is
Frigidiare Parts& Service
7075 Ordan Dr.
Mississauga,Onterio L5T 1K6
Tel# 905-565-9200
GENE
Directions how to use self cleaning over on the fridge re gallery gas stove
Hello, Joan -
Clarification: You are asking about a Frigidaire Gallery model gas stove and how to use the self-cleaning feature for the oven? If so . . .
You will find the instructions here:
https://www.hunker.com/12002208/instructions-for-a-frigidaire-gallery-series-self-cleaning-oven
If you need the user manual for your oven, you can add the model number by choosing Comment and adding the information there, so I or someone else volunteering to answer on Fixya.com can look for and provide the right link for a download of a free manual.
Note: There is more than one Frigidaire Gallery range model numbers made:
https://www.frigidaire.com/Kitchen-Appliances/Ranges/View-All/?filter=Feature02012:Feature02012
Best wishes.
4answers
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
1helpful
I have the Frigidaire Gallery slide in stove/oven. The display for temperature is so dim that I can't see it anymore. Would it be a fuse?
The Electronic control has lights inside for the time and for the temperature. Over time the lights get dim (Frigidaires do it a lot). The Electronic control is not a Servicable part. You must buy a new Electronic control.
How do I chance the time on Frigidaire Gallery stove, to move it ahead one hour
Press clock button, then press temperature up button. Time will begin to change. When you have the correct time set, press the clock button again to save.
1helpful
F-3 is showing on my oven display while in use and the oven shuts off.
The problem is the oven temperature sensor, this is located inside the oven near the top. For diagrams and illustrations of your specific model go to www.appliancehelponline.com and enter your model #
Oven temperature sensor is open (above 3000 ohms)
Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Top element wont heat wen oven is on bake
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
1helpful
2answers
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
1helpful
Frigidaire Stove model # 791FEFS66DS has a F10 error. Help Please!
F10 is a Runaway temperature issue.
There are three possible scenarios:
1. The temperature sensor has failed.
2. The electronic control has failed
OR
3. The connector between the temperature sensor and the electronic control has failed.
The connector can be troublesome. The first thing to do is eliminate this potential issue.
  • Remove the back panel.
  • Locate the temperature sensor plug
  • Cut the plug off the temperature sensor wires and the corresponding electronic control wires
  • Using ceramic wire nuts, secure each temperature sensor wire to the corresponding electronic control wire.
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
