Necchi 3101 Mechanical Sewing Machine Logo
Posted on Sep 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ned a diagram (or detailed instructions) on to thread a Necchi 3205FA & installing the bobbin. Thanks.
Tally Girl
Level 3:
  • Necchi Master 1,134 Answers
  • Posted on Sep 20, 2011
Tally Girl
Necchi Master
Level 3:
Answers
1134
Questions
0
Helped
398683
Points
2496
Try www.sewusa.com there are threading diagrams for some Necchi models. even if yours isnt there the bobbin should be similar.
How to thread a Necchi 3205 FA royal series
Search for:
Make Model threading
or
Make Model manual
https://www.sewingpartsonline.com/instruction-manual-necchi-3205fa-sewing-machine.aspx
Even if not your particular model, basic machine threading is very similar from one to another. Just be sure to ALWAYS RAISE the presser foot when threading the top thread---and change the needle often.
How do thread Necchi Royal Series Model 3205 sewing discussion topic...
How to Thread Necchi Sewing Machine
How to thread Necchi model 535 FA sewing machine now with captions
2answers
Top thread too tight?
make sure tat the thread is between the tension plates and not behind and jamming on the bolt
proper tension is a slight resistance when you pull the thread to thread the needle
Do you have a demonstration or diagram of how to thread and install bobbin for necchi 537L sewing machine?
Try this web site:
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
May not have your exact machine but one may be similar enough so you can thread your machine properly.
I can see the top tread coming the on to the bottom of material what do I do on my necchi 3205FA sewing machine?
adjust tension of the upper thread (tighten) (shown with number) , & check thread routing. image is just for reference only.
1helpful
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
1helpful
The needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
1helpful
2answers
Necchi Heavy Duty Sewing machine model 3205FA, bend needle while hemming denim skirt, replaced the needle, but now the needle is not picking up the bobbin thread, any suggestions for me to try???
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
