SOURCE: dell 1800 power edge is giving long beep continuously.
Power supply, system board, or keyboard problem
SOURCE: Windows - Delayed Write Failed
This points out to a problem with one of your hard drives. Run CHKDSK on all drives you have, & if any problems are detected on any drive, run CHKDSK /F on that drive.
SOURCE: high pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
SOURCE: power edge loght is red and blinking
You
should be able to see the reasons in the front panel, remove the
front cover and you will see a small display with some information
passing slowly. Sometimes is just the redundant power-supply that is
disconnected.
SOURCE: NO HARD DISK FOUND DELL POWER EDGE 2950
Your probably got one ofthe following:
1. har drive crash
2. Hdd controller failure
Ether witch will need replacment parts and that you would see a local tech for if you do not know what your doing. You might need a new hard drive or acontroller in this case.
Thanks and please do be considerate and leave postive feedback ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Suggested Resolution
Solid green
Power is on, and the computer is
operating normally. On the desktop computer, a solid green light
indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
