20 Most Recent Dell Dimension 3100 PC Desktop Questions & Answers
The hard disk is dead. To recover some of your files from it just boot from a Linux Live-CD like   http:pclinuxos.com/  and copy whatever you can recover to a USB memory stick.
Dell Dimension... | Answered on May 17, 2019
I think your Thermal Paste on the CPU HeatSink might be dry. When this happens it like metal touching metal and the computer shorts out so it can't boot. You need to open the case and you will see 4 screws that hold the cpu heatsink on top of the processor chip. There are lots of videos on Youtube that show you how to replace the thermal paste (sometimes called thermal compound). I'm going to post a link here to one. I normally apply a thin coat of the paste all over the cpu and also on the heatsink. Then I put a coat of the paste in the middle of the cpu just like the video shows. This insures that I have coating all over the cpu and the cpu/heatsink. Don't worry as the video says about letting it dry. Put it on and turn your computer back on and start using it. https://www.youtube.com/watch?v=BQgCUcAAdac
How to Replace Thermal Compound
Dell Dimension... | Answered on Jul 02, 2018
when you say reimage, do you mean dell's pc restore? what's the error message and at what point does the error message appear?
Dell Dimension... | Answered on Dec 08, 2016
Remove whatever USB cables in the front USB ports below the DVD. Then try starting it should work. If not remove USB from the rear one at a time. Once it restarts replace USB cables into ports.
Dell Dimension... | Answered on Aug 12, 2016
I have met the same problems, just visit Mannualbirds.com to refer to the DELL 3100 manual, your problem will be well solved! View Dell 3100 PDF User Manual Online
Dell Dimension... | Answered on Nov 24, 2015
Got some Dell Manual,check these manual for your problem http://www.manualbirds.com/brands/free-dell-manuals
Dell Dimension... | Answered on Nov 13, 2015
Hi, to release computer from standby mode, you could remove battery, put it again an turn on computer, Windows will show computer was not turned off correctly but now you can continue using it.
Dell Dimension... | Answered on Nov 08, 2015
go to bios setup and select first boot device as usb
Dell Dimension... | Answered on Nov 06, 2015
link below may be of assistance
Dell Dimension... | Answered on Jun 24, 2015
Unplug the unit from electricity, wash & dry your hands, take steps to avoid you transmitting static electricity(look it up if you are not familiar). There are several sheet metal screws around the edge in the back of your CPU. Remove the ones that appear to join the outer lip to the inner lip all the way around. The front & back should now separate into 2 pieces. One the shell & the other the bulk of the system. The hard drive is usually located on a standard mounting shelf by itself with 1 or 2 small screws holding it in on the side with 2 wire connections in the back. The larger is a ribbon cable the is used for data & the other is the power cable. pull out the cables, unscrew the screws & the hard drive slides out. Some boxes may have something that blocks your access to screws, if so, temporarily remove them so you can work. If you are not sure of a potential problem...take a smart phone picture so you can see how it goes back together.
Dell Dimension... | Answered on Jun 22, 2015
http://www.kobo.com/accessories/kobo-charging-kit.html
Dell Dimension... | Answered on Jan 05, 2015
Means that that device is defective or missing software drivers.
Dell Dimension... | Answered on Jan 03, 2015
Please remove any and all USB devices, DVD/CD's, floppy disks from the PC then power it off completely and try to boot again. If it boots properly it simply means one of those devices is set to be bootable but isn't set up to boot your computer. To identify replace one at a time and reboot until the problem returns. Should removing all of them fail, chances are your windows drive has failed and needs to be replaced and re-installed with windows. Dell's generally arrive with a set of DVD's that can be used to set up a new drive, this will get you running again but you will need professional help if there was anything on the original drive that requires recovery.
Dell Dimension... | Answered on Oct 02, 2014
The blinking light does indicate power problems here is the exact message: "The power supply is receiving power from the source but is unable to properly distribute it to the components." I would suggest pretty much the same thing. Remove any additional components you can, reboot and see if the problem still persists. If it does I would call back informing that with only the basic componets it still fails. If you are able to boot to windows go to system in the control panel and under the advanced tab unclick the option 'automatically restart on system failure' something to that affect. That would give you an error message that may diagnose the problem more specifically. You would have to verify with dell if you could get a larger power supply for that particular system.
Dell Dimension... | Answered on Aug 13, 2014
This desktop has a motherboard in it that has an intel LGA 775 processor socket in it. From the spec's I found the cpu that ships with the system should be able to scale up to 3.5 Ghz. But you should be able to replace it with any Pentium 4 that fits into an LGA 775 socket.
Dell Dimension... | Answered on Jun 24, 2014
This is generally an indication of boot failure , often as a result of new hardware addition or new software installation. Try pressing the F8 key repeatedly (about once per second) while booting and boot in safe mode. If no success , try removing any hardware (especially flash drives) that was added since the last time the machine worked and try the above again
Dell Dimension... | Answered on Jun 02, 2014
Suggest you go to attatched link add check out the battery (XBT!) shown in the motherboard photo. A battery short can cause this and similar problems.
h20565 www2 hp com
set the date in cmos. if the date changes again replace the cmos battery.
Dell Dimension... | Answered on May 14, 2014
Dell Dimension 3100 PC Desktop Logo
762 questions posted
Clive
Clive
Alun Cox
View Most Popular
Dimension Dell
  • Dimension Dell
Most Popular Question
start up blue screens hd check gvies
  • Computers & Internet
