SOURCE: carving stone with a rotary tool
Are you asking for permission? If so, it OK with us, better check with your wife and her mother.
SOURCE: My dremel 10.8 lithium ion
The battery has been overcharged.
You will need a new one.
Thanks!!!!
SOURCE: I have lost my user's manual for the Dremel 400
you can try going to "dremel.com" and downloading the manual, also there they have a toll free number for tech support which might be able to send manual as a PDF file. Let me know if you have trouble finding it and I will come up with another source
SOURCE: Dremel 395 Rotary tool won't turn on or
Electrically speaking there are a few items to check. 1) The easiest is to remove the two brush holders screws on each side by the power cord. If one of the screws are loose, or the bushes are worn you will get intermittent or no operation. 2) Second use a volt ohm meter to make sure you have voltage on the two brush connectors inside the brush holders when power is on. If you do then open the unit a check continuity on the motor armature to see if it is open, which will cost $13.37. If you do not have voltage, inspect the power cord and switch. Some parts can be purchased on the below link. Or contact a dremel service center from the link below. http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
