20 Most Recent
Dremel 8000 01 Cordless Rotary Tool Kit Variable Speed 10.8 Volt Lithium Ion Questions & Answers
Dremel 10.8V cordless model 800 (8000) The speed
You are right,it will need a slider switch replacement,But first-is it still under warranty?If it is call the costumer support on their 1-800 ...number.If not you could DIY it.Opening the drill is not that hard and as long as you observe the proper orientation and where every wire is connected to,you will be able to disassemble the unit.Inside you could see where the slider switch is connected and how it is positioned.Usually the surface of the switch is burned out and this you have to replace.The next problem is locate the part number it is usually found printed under the slider part.And the next big thing is to order the part and where to order it.Consult the user manual that came with Dremel unit and the ordering address is there.
I have a DREMEL 10.8 Volt rechargable. While using
I love Dremel I really, do but they have issues like all tools.
I know how to fix it but there is no places that sells the parts... If you can find one that had its motor blow, like from a friend, neighbor, or co-worker, you can swap out the parts your self...
I personally only buy craftsman. You can not beat a good warranty.
Battery on my cordless dremel will not charge.
Dremel Stylus AC/DC Adapter 230/240V Transformer primary is open circuit any idea what the AC output of the transformer is. I should be the same for 110V input transformer. If I can find the output voltage from the transformer I can probably get a replacement
Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
New dremel
It was just retired there is nothing recalled its just an old model
Cut out tool Comparison
Cut out tools are available in both cordless and corded versions. Cordless tools can be more convenient. The corded versions are slightly more powerful than cordless.
Looking for the service manual for a weller mini shop model 601 Dremel tool
I'm sorry, but I don't have access to specific service manuals for individual tools. However, here are some steps you can follow to find a service manual for your Weller Mini Shop Model 601 Dremel tool:
- Visit the Weller website: The Weller website may have a library of manuals for its products, including the Mini Shop Model 601.
- Check the manufacturer's support page: Most manufacturers have a support page on their website where you can find user manuals, FAQs, and other resources.
- Search online: You can also try searching online for a digital copy of the manual. Websites like ManualsLib and ManualsOnline may have the manual you need.
- Contact the manufacturer: If you're unable to find the manual online, you can contact the manufacturer directly and request a copy. You may need to provide your tool's model number and other information.
I hope this helps you find the service manual for your Weller Mini Shop Model 601 Dremel tool.
