SOURCE: Electric Whirlpool Accubake burners turn off after 20 seconds.
replace igniters for both burners.
SOURCE: whirlpool accubake sf367lxsq top burners work oven
You need to check for continuity between the bake relay output terminals and the broil relay output terminals. If the bake/broil function is supposed to be on and there is no continuity, your board must be replaced/repaired. The company I work for, ApplianceTimers.com can repair your failed board. If there is continuity, you have a shorted external wire(s) or element.
SOURCE: Have XR 3808161 Whirlpool Accubake
Hi F2 Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
