My sansa e280 shows that i have 266 songs. when i press to play the songs it shows "bad track", even after i've attempted to delete all the songs. it plays nothing!
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
I experienced a similar problem caused by corrupt files saved on the internal memory of my e280. (I could not delete/remove the files) I had to format the internal drive of the e280 and re-copy the files back on to the unit. Works great now. When formatting the device use the command from windows. (ie right click on the internal memory icon and select format)
Note: Formatting will remove/delete all the files (eg music,photos..) from the e280 so make sure that you have backups.
I should have Googled this before posting. I'm not sure if I found the solution here or elsewhere but... I deleted the /system/database folder and after it restarted and rebuilt the database the 'Bad Track' was gone. I was able to load the player with MP3s and it has worked flawlessly since.
That means that somewhere in your music collection is a song with bad formatted ID3 tags. You can download an ID3 tag tool like MusicBrainz Picard to go through your songs and determine which tracks might be bad.
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there. Either under sync pane in windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete. Hope this helps If you still not able to delete it let me know so I can have you try something else... P.S.Please rate accordingly... Thank You Computerrep
Some DRM-encrypted files have a fixed time limit for how long you can use/play a song. after the time period has lapsed, they will show up as "Error - File Format..." (this is only one possibility)
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
