It comes on in Ready mode and the light does glow when I try to copy. It does not move across and back.It comes on in Ready mode and the light does glow when I try to copy. It does not move across and back.
You can't post conmments that contain an email address.
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key. Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Check the yellow toner cartridge, printing a configuration page.
Configuration page The Configuration page lists the current settings and properties of the printer. You can print a Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer, complete the following steps. 1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu. 2 Press the button (SELECT). 3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report. 4 Press the button (SELECT) to print the Configuration page.
Yellow print OK? No? try print with another yellow toner cartridge (Q6002A).
This is a problem with either the formatter board or the dc controller, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Hi
You go to the Main Menu on the physical printer, then you look for reports , hit enter and finally look for "usage page"
This will show the number of copies you have printer with the unit
You can print a configuration page using the control panel of the printer, it would have the option page count in that configuration page.
To print the Configuration page from the control panel
1. Press (LEFT ARROW) or (RIGHT ARROW) to select the Reports menu.
2. Press (SELECT).
3. Press (LEFT ARROW) or (RIGHT ARROW) to select Config Report.
4. Press (SELECT) to print the Configuration Report page
Page Counts. This section lists the total number of pages printed, the number of color
pages printed, and information about paper jams.
