SOURCE: power
Yes Eric. The power supply can be replaced and it's rather easy.The only problem is finding one for sale. They are fairly hard to come by. Try ebay, but BE CAREFUL what you buy and read the description VERY well.
I hope this helps you out. Good luck to you.
SOURCE: PS3: No image or sound.
the power unit probably got damaged also try another tv and look for your proof of purchase you mite still get it replased for free either from the store you bought from or SONY.
SOURCE: i tried yesterday 6-7 times to turn it on
Hard to deduce but it could be a issue with the BIOS/CMOS chip too.
Is the Vaio still under warranty ? If no then unfortunately, would need to have it checked again at the service center and follow those guys :(.
If its showing past time than that indicates (1) the CMOS battery is dead (2) Motherboard circuitry has issues.
SOURCE: I've owned a KDL-32L504 for exactly one year...
hi,
faulty power supply. replace the surface mounted pwm generator ic on the power supply and check /replace bad capacitors on secondary section of power supply.
A
quick fix for most communication errors can be achieved by resetting the
printer and/or rebooting the PC. Simply disconnect the printer from your
computer. Reboot your pc. Unplug and re-plug the printer into the power source
to reset it. When the printer turns on, reconnect it to your computer. Then try
to print again once the computer fully recognizes the USB connection.
If
that doesn't help, try the steps below:
1.
Disconnect the printer from your computer.
2.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds).
2.
On your computer, go to Control Panel > Printers and Faxes.
3.
Delete the Lexmark print object.
4.
Reboot your pc.
5.
When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
A
If
1.
2.
seconds).
2.
3.
4.
Reboot your pc.
5.
6.
list, then try to print again.
You
may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/9xPHL4.
Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
