20 Most Recent Sony SDM HS93 19" LCD Monitor Questions & Answers
0answers
Monitor light up then shut down itself
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor. 2. Verify the monitor cable is firmly connected to the computer and the monitor. 3. Verify that you have turned the monitor power switch on. 4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works). 5. If the power light on the monitor is not on, try a different power cord. 6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
5/28/2014 5:18:14 PM • Sony SDM HS93... • Answered on May 28, 2014
2answers
Sony SDM HS93
i get same..controls not working ,,sometimes menu button works and one arrow button..button "ok" button doesnt work and up arrow...brightness not working.
i get black box in upper left corner...quite diffucult to get rid of.
G
[email protected]
2/11/2013 12:47:49 AM • Sony SDM HS93... • Answered on Feb 11, 2013
My monitor flickered occasionally and one day went
Check the caps in the power supply first, hopefully it will not be bad lamp assembly as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
the HS-17 also has bad lamps problem.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
12/24/2010 5:01:08 AM • Sony SDM HS93... • Answered on Dec 24, 2010
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
4/18/2010 4:10:33 AM • Sony SDM HS93... • Answered on Apr 18, 2010
My Sony SDM-HS93 has a VERY intermittent
Common failure in the SDM-HS73/93 is the bad lamps assembly due to poor soldering works.
Service manual: http://elektrotanya.com/?q=showresult&megnev=SONY&megnev2=SDM-HS93&kategoria=monitor&kat2=all
Pictures: http://s807.photobucket.com/home/budm/allalbums
4/12/2010 4:57:02 AM • Sony SDM HS93... • Answered on Apr 12, 2010
Cant get on sony acid music studio 5.0 cause i dont have my serial number anymore please help
We can't helpwith that but you could contact your software supplier and ask for a copy.
4/10/2024 11:55:56 AM • Sony Computers &... • Answered on Apr 10, 2024
Sony Vaio PCG-9S1L. Can anyone upload the owner manual. Thanks
Question edited for clarity, and toss in CAPS. Duplicate question deleted. Refresh page to see your question. Whatever you are trying to do with this Mr Chan, you are wasting your time. It is a Vintage computer running Windows 7. The manual is here
Sony VAIO PCG series Manuals
ManualsLib https://www.manualslib.com > ... > Laptop We have 1 Sony VAIO PCG series manual available for free PDF download: User Manual. Sony VAIO PCG series User Manual (202 pages). https://www.google.com/search?q=Sony+Vaio+PCG-9S1L+owner+manual ....
4/6/2024 7:02:02 PM • Sony Computers &... • Answered on Apr 06, 2024
Sony VRD-MC1 DVD RW Dual Layer. I have been using it many years, but have problems. What do I have to do now please?
Question edited for clarity and made into written English. If you got 6 to 10 years use, you just buy a new one for $15.97. https://www.google.com/search?q=Sony+VRD-MC1+DVD+RW+Dual+Layer ..
10/26/2023 1:10:51 AM • Sony Computers &... • Answered on Oct 26, 2023
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off. These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
9/18/2023 2:00:07 PM • Sony Computers &... • Answered on Sep 18, 2023
Where can I get Sony Control Cables needed for ST-S101 & TA-F101r?
Depending on your location. You have to go to a computer accessories closest to you. Yes you can definitely get it.
7/22/2023 7:40:47 PM • Sony Computers &... • Answered on Jul 22, 2023
Sony sound forge pro 11.0 serial number
Magix can supply you with that.
SOUND FORGE Pro - Download music editing software free
Magix https://www.magix.com > music-editing > sound-forge... SOUND FORGE Pro enables professional audio editing at the highest level. Download the music editing software now for free! ..
7/9/2023 6:13:23 PM • Sony Computers &... • Answered on Jul 09, 2023
I need an amplifier board for my Sony HCD-GNV111D / MHC-GNV111D
this is a question and answer forum manufacturers do not read this forum. You may want to look on eBay or other places that sell parts.
6/28/2023 3:26:24 PM • Sony Computers &... • Answered on Jun 28, 2023
Sony Vaio VGC-LM1E Recovery reinstall
Windows Vista Home Premium? It is an antique, throw it out! That is the most hated version of Windows ever produced. Your old hard drive has an embedded serial number and that is part of the credentials used to load your original copy of Windows and authorize the copy. However, that should come later when you enter the Product ID did you format the hard drive first? format C:\ /s if I remember correctly at CMD Prompt Your question is at Tom's Hardware! https://www.google.com/search?q=Sony+Vaio+VGC-LM1E+install+and+format+hard+drive ..
5/30/2023 8:30:03 PM • Sony Computers &... • Answered on May 30, 2023
Why can't Alexa change my TV channel with Sony Basic TV app?
Not sure who you are talking to in the 'Additional Information' box below your question. You may have be talking to an AI Answer Bot which has had its answer deleted. That box up there is for Experts to ask you for further information before committing to an answer. The correct way is to click Comment under the Answer you are replying to. Sony seems to think it can be done.
Connect your TV to the Amazon Alexa app
Sony https://www.sony.ca > electronics > support > articles On the Amazon Alexa app: Open the Amazon Alexa app on your smartphone, search for BRAVIA, and then select Sony's TV - Basic Skill and enable it. Note: If you ...
FAQ - Control your TV with Amazon Alexa devices
Sony https://www.sony.com > electronics > support > articles For TVs with the TV Control Setup with Amazon Alexa app: Select the Sony's TV - Basic skill, and enable it. Alternatively, you can also enable it by ...
5/16/2023 4:39:29 PM • Sony Computers &... • Answered on May 16, 2023
2answers
Need to reset password for SONY VAIO PCG-7142L.
Solved - password reset or removal
Vista Forums https://www.vistax64.com > ... > General Discussion Its a Sony laptop with a windows vista home premium OEMAct, model pcg-7142l . I don't know if it is a bios or vista password.
How to remove the log in password.
Sony https://www.sony.com > electronics > support > articles Nov 17, 2016 - Refer to the operating instructions supplied with the computer for model-specific information required to complete a format and recovery ...
How to Reset Password on Sony Vaio Laptop Windows 7/8 ...
PassCope https://www.passcope.com > how-to-reset-password-o... Here, we are going to specify how to reset the password on Sony Vaio laptop using various alternatives for Windows 7/8/8.1/10.
5/9/2023 8:17:20 AM • Sony Computers &... • Answered on May 09, 2023
Sony SDM HS93 19" LCD Monitor Logo
9 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SDM Sony
  • SDM Sony
Most Popular Question
monitor light up shut down itself
  • Computers & Internet
