20 Most Recent HTC G1 Questions & Answers
you need to factory reset your phone. this website shows you what to do without having to access anything on your phone - the first step is shutting it off. follow these steps and your phone will turn on, the only drawback is it will be like its new, and you'll have to re-download all the apps and stuff. it also has you sign up for gmail, and i suggest that you create a gmail address and write it down so it doesnt happen again :)
http://androidcentral.com/factory-reset-tmobile-g1/
HTC G1 | Answered on Aug 04, 2018
you most likely have an error in your pop3 settings exchange server also suppport imap see if you can delete the outlook settings and then create a new connection using the correct pop 3 information or try imap ask your system admin what the imap settings are because pop 3 is no longer used as much
HTC G1 | Answered on Feb 16, 2018
My phone comes up with a message about once a week that says "You have not rebooted your phone in several days. you should reboot to keep things working properly". That is what I would try first.
HTC G1 | Answered on Dec 23, 2017
I've had a similar problem. My solution was to install a third party app, which can twick the settings of the audio. You can find lots of apps like this one: How to fix all Audio Speaker Microphone problems in Android Sound About .
HTC G1 | Answered on Nov 26, 2017
Again reset the Phone then try to log in your Google account on the desktop after, if login successfully then log out and again login google id on your phone.
HTC G1 | Answered on Oct 24, 2017
take you problem to any optus shop and it will be sorted out by the it people
HTC G1 | Answered on Oct 20, 2017
If you had come here and said "I am going to Root my phone, any advice"? All of the Experts here would have shouted DON'T DO IT!
Rooting programs are written by amateurs, and unfortunately you have seen the result. You have altered the firmware which is the hard written instructions for the phone to boot, much like the BIOS in a computer.
We see your problems on a weekly basis. My standard reply is "don't Root your phone unless you want a paperweight". You now own a paperweight. Buy a new phone, learn the lesson.
HTC G1 | Answered on Feb 28, 2017
i know how it sucks when you purchase a new mobile and you face something like this. But i have an answer for you. i had the same problem last week and i have found a solution from one of my friends. this problem happens when you open many programs at the same time and the programs are stiull running under. To solve the problem go ahead and turn off your G1 mobile for about 30 seconds. it will start working when you turn on your G1. turning off your G1 will close all the programs running under...good luck
HTC G1 | Answered on Feb 27, 2017
The G1 Doesnt support Bluetooth A2DP yet, meaning it cant stream music via Bluetooth. Yet !
HTC G1 | Answered on Jan 05, 2017
You can use motorola V3 charger as an alternative charger,htc charger is difficult to find and expensive as well,i'm also using the same phone as yours and i never had a problem using motorola charger,but if you really want HTC charger,you can go to CITY PLAZA at Quiapo,manila,but not sure of getting original charger,only class A is available,or even go to any mall nearest you,might spot original HTC charger as well.
HTC G1 | Answered on Dec 03, 2016
open your music files select your music to be used as ring tone. hit menu. then use as ringtone
HTC G1 | Answered on Jul 31, 2015
well obviously the market app wont work until you have an active wireless connection. But it also sounds like the market app is corrupted. Connect your g1 to a wireless network with internet access and then go into settings and tell it to search for updates. That might fix it
HTC G1 | Answered on Feb 24, 2015
G1 Manual
HTC G1 | Uploaded on Jan 21, 2015
G1 Manual
G1 Manual
G1 Manual
HTC G1 Logo
1,248 questions posted
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
G1 HTC
  • G1 HTC
Most Popular Question
phone locked
  • Computers & Internet
