ViewSonic VX2835wm Monitor Logo
Anonymous Posted on Sep 02, 2011
VX2835wm. When plugging in to wall, screen flashes for about 2 minutes; there is no yellow no blue LED. It will not respond to on off button until it has finished the flashing routine.\r\nThen blue LED comes on and monitor works OK. If I shut off the monitor for up to about 1 hr, it turns on properly. After that, it's back to flashing for the first 2 minutes. It doesn't matter what computer is connected or if no computer is connected. I have replaced 2 470ufd and 3 1000ufd caps that looked slightly swollen. All other caps look physically OK and I'm trying not to replace ALL caps hoping that it's one of them. Anyone have suggestions on the likely component? I want to do component level repair.
Anonymous
Level 3:
  • Master 1,833 Answers
  • Posted on Sep 02, 2011
Anonymous
Master
Level 3:
Answers
1833
Questions
0
Helped
555354
Points
4774
Hi, According to your problem, Check the adjust switches and readjust the monitor first. You have to repair the PCB of the monitor. Better if you can replace the PCB of the monitor.
PROGRAM NEW DIGIDOOR 3 WALL CONSOLE
To program a new wall console for your Digidoor 3 to the receiver, follow these steps:
  1. Connect the receiver to a power source and turn it on.
  2. Press and hold the "Learn" button on the receiver for 5 seconds. The LED light on the receiver should start flashing.
  3. Press and hold the "Learn" button on the new wall console for 5 seconds. The LED light on the wall console should start flashing.
  4. Release the "Learn" buttons on both the receiver and the wall console.
  5. Press and hold the "Open" button on the wall console for 5 seconds. The LED light on the wall console should stop flashing and the LED light on the receiver should start flashing.
  6. Release the "Open" button on the wall console. The LED light on the receiver should stop flashing, indicating that the wall console has been successfully programmed to the receiver.
If the above steps do not work, you may need to reset the receiver and try the programming process again. To reset the receiver, unplug it from the power source and wait for 30 seconds before plugging it back in and repeating the programming process. If you are still having trouble, you may want to contact the manufacturer for further assistance.
Viewsonic VX2835wm. With on/ off button sometime does not respond. Have to pull plug to "reset" it.\r\n After start working keeps working as long as I don't shut it off. Instead of switching...
Yes, it can be unstable DC voltage problem due to high AC ripple because of the bad DC filter caps, you need to inspect the power supply section for any caps with bulging top or bottom seals on the cap. Bad cap can look normal but can have high ESR.
The VX series are known to use alot of bad caps as you can see in my pictures here: http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/
Alos look at the caps in the main board also.
Please post back what you find.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Battery? console has no charge when plugged into wall outlet I push power button blue LED comes on briefly , then red flashes 3 times, and the yellow LED lights up along with the health warning on the...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
    If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly.
    If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will display Nintendo's logo.
    Call 1-800-255-3700 if you still need help.
1helpful
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
2answers
6helpful
4answers
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
2helpful
3answers
Powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
 The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
