Ask them exactly what happened just before it went off or the last time they used it. May be they spilled a drink on it. A knock will leave scratches/broken screen.
F755US (about 10 years old) A LAPTOP
runs VISTA new, is it?
is the PC silent, no fan spins , no sounds at all?
take out the big battery first bottom , with latch.
do that now.
got text to screen now, fan blows air.
got logos of any kind to screen
got "Hit F10 for HP setup?" works on screen seen for 10 years every time you turn it on.?
does the F10 if prompted above.
is the line power pack AC , have damaged cables or ends?
this PC will have 3 major failers at 10 years. as all laptops do. this old. ALL
1; RTC coin cell dead. replace it.
2: main battery is bad, worse shorted run PC with no main battery NOW.
3: the CCFL back lamps so not last 10 years. unless
the laptop spent its hole life parked on a shelf turned off.
4: BAD HDD, (last) if the PC is silent say so please.
are the blink or beep codes happening?
is the PC silent. with the big battery out (bottom latches) and AC pack at wall jack power good.
we have 20 more questions
but that is first.
easy no? it's 1 question day.+
Compatible AC Adapter for Compaq Presario F755US Laptop
I think it has a bad power adapter yielding insufficient voltage.
This system is running Vista which makes it quite dated. However, you can try the replacement supply and see what happens. Or, they coud view Utube on an inexpensive android tablet.
However, you can try the following (I am guessing you do not have the Vista disc):
To boot into the Advanced Boot Options menu, follow these steps:
Some of these options will if operating at all restore your computer to factory defaults erasing data and programs installed after it first came out of the box.
not starting up has many meanings.
dead
silient,
text gone but fans blow
WIndows log in screen dead or stalled.
or bios passwords lost.
got text on screen only, but what?
even blue screens of DEATHH, BSOD's
SOURCE: power on password fix
press delete to go into bios and turn off password protection if you cant do this try disconecting the hard drive first then do it and replace hard drive when its off use f10 to save and exit bios
SOURCE: hello. i have a compac presario f700 notebook pc.
motherboard drivers
compaq laptop c700 drivers
Extra documents: http://h10032.www1.hp.com/ctg/Manual/c02... andhttp://h10032.www1.hp.com/ctg/Manual/c01...
