Master
- Posted on Aug 30, 2011
Re: Looking to find the frequenecies of the upper and...
- Hi I can help.
- For the Grant 40 channel CB there are 40 frequencies I will list below.
- When you refer to the upper and lower channels for this raidio you must mean USB (Upper Side Band) and LSB (lower side band).
- This is called single side band modulation which is to say the the carrier is removed from the upper or lower sideband depending on which your pick and the signal goes farther on less power.
- So the upper and lower side bands are the same frequency just upper side band or lower sideband.
- 26.965 MHz 21. 27.215 MHz
- 26.975 MHz 22. 27.225 MHz
- 26.985 MHz 23. 27.255 MHz
- 27.005 MHz 24. 27.235 MHz
- 27.015 MHz 25. 27.245 MHz
- 27.025 MHz 26. 27.265 MHz
- 27.035 MHz 27. 27.275 MHz
- 27.055 MHz 28. 27.285 MHz
- 27.065 MHz 29. 27.295 MHz
- 27.075 MHz 30. 27.305 MHz
- 27.085 MHz 31. 27.315 MHz
- 27.105 MHz 32. 27.325 MHz
- 27.115 MHz 33. 27.335 MHz
- 27.125 MHz 34. 27.345 MHz
- 27.135 MHz 35. 27.355 MHz
- 27.155 MHz 36. 27.365 MHz
- 27.165 MHz 37. 27.375 MHz
- 27.175 MHz 38. 27.385 MHz
- 27.185 MHz 39. 27.395 MHz
- 27.205 MHz 40. 27.405 MHz.
- If you have any comment please feel free to leave them here.
- Hope this helps and thank you for using FixYa.
Regards,
Tony
